Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hooking up a PS3 through HDMI
I have my PS3 hooked up to the tv through HDMI, but the tv wont recognize the hook up, i know i have to load the PS3 HDMI set up in the menu but its still not recognizing it when i try to set up, it only works through the yellow red and white cables when the tv is in game mode. When the PS3 tries looking for the active HDMI connection it goes back to default saying the connection was not available. Same Issue, will not recognize, nor go to 1080p resolution
  • 6 more comments
  • deeeoghan Mar 08, 2008
  • Anonymous Mar 28, 2008
    i cannot get a signal on my tv
  • Anonymous Apr 01, 2008
    same
  • Anonymous Feb 08, 2009
    I try to load a blue ray movie with the ps3 and it appears to load. Then the top corner where it lists 1080 p or i or 720 whatever appears. The 1080p dissappears and then the screeen goes blank. I can hear the music but no picture.
  • Anonymous Feb 23, 2009
    my hd cord is not
  • snakkec Feb 23, 2009
  • Anonymous Mar 21, 2014
    Do you know what the display settings are, enabling me to connect my Macbook Pro to my RCA Plasma TV?
  • Anonymous Mar 23, 2014
    I have an Auvio 32" Soundbar SB32200 not a bluetooth, we can only use it with the headphone hook up and it keeps going in stand by mode, when I try to hook it up with the red and white aux hook ups it won't work, what am I missing?
What you have to to is hold the start button till the TV shows 480i then you will have what you need, it will set up for your tv
Posted on May 03, 2008
Hold the power button on your ps3 while it until you hear the 2nd beep then follw the on screen prompts that should get you there
Posted on Nov 28, 2011
  • mamatude33
    mamatude33 Dec 24, 2012
    Thank you soooo much for that suggestion, that worked!!!!
    President:
  • 1,284 Answers
IS this a 1080p TV? If not then use 1080i or 720p.
Posted on Feb 21, 2008
How to hook a ps3 to a protron tv
How are you hooking it up to your TV, through the AV color cords or HDMI, or HD AV cords?
Oct 20, 2014 | Sony Playstation 3 (PS3) Console
Would like to hook up playstation2 can you help with this
I would suggest hooking up via HDMI or via the composite cables. Then all you should have to do is turn on your ps3, change the input on your tv to whichever port shows the ps3 or new input device. If it doesn't for some reason recognize it as ps3, you can always go into more detail using the tv to rename that port as the PS3. Hope this is what you wanted to know!
Feb 07, 2012 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have a HDMI problem with my PS3. I have it
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
May 14, 2010 | Sony Playstation 3 (PS3) Console
Try entering Recovery Mode and choose "Restore Default Settings".
If that doesn't help, you may have an HDMI port failure - which will require returning the unit to Sony or sending it to a third-party PS3 repair shop.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
We're hooking up our PS3 to a new television....and it keeps telling us there is no signal...what could be the problem?
be more specific about the problem, r u using original wires or HDMI? what kind of TV is it? and have you tried hooking up a dvd player or other devise to make sure the TV is not defective? and if you switched connections(HDMI to regular cables or vise versa) u have to change the settings on the consle under DISPLAY SETTINGS using the same connection you were using on the other TV.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
I just bought a PS3 slim and hooked it up to my 65'' Toshiba DLP TV using a HDMI cable. The problem is i have picture but no sound. I have tried the settings and all seems to be fine, also tried different...
not 100% sure but check the manual for your tv it may be that you need a faster hdmi cable, as with having a larger tv it will work at a faster rate so the basic hdmi cables wont work.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Aug 02, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
Line going up and down TV when i play ps3?
did you reset the setting in your xmb on your ps3 from hdmi to a/v cables?
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
5,637 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
