Question about Acer Aspire 5610-4648 Notebook
Computer Screen Image too small when shown through LCD Projector
A teacher hooked her Dell laptop (running Windows XP) up to an Epson Model EMP 8 LCD Projector. The image did not fill up the whole screen of the Epson projector. It was quite small.
We tried resetting the screen resolution, toggling through Fn F8 (external monitor function key). None of this helped.
Do you have any suggestions for making the computer image fill the projector screen? Thank you.
  • Anonymous Mar 17, 2014
    Only see blue screen when I hook up my Dell computer to my Dell 3400 projector
  • Acer Master
  • 12,061 Answers
You may have to setup the EXTERNAL resoloution for a bigger picture than can generally display on the lappy's screen... there is uaually a setting for the dual display setup... Right Click desktop and click Properties, the video settings can be acessed from there... Also ensure ya have the latest most up-to-date drivers for ya lappy's Video too.
Posted on Feb 08, 2008
I have a DELL XPS 15 Laptop. I tried to connect the laptop to different lcd Projectors using HDMI to VGA connector. The laptop could not be connected with any of the lcd projectors and no projection on the...
Hi
Sure can be fixed.
1st of all you need to connect the projector with your laptop turned off. One the laptop has finished booting and loading windows. Hit the Fn+f4 or f7 key to switch between the displays then you will get the display.
But if this also does not give display then you can check with the projector with Video INPUTS (Eg. Input 1 / Input 2 etc.,)
Jul 21, 2011 | Epson EMP-S5 Projector
Hi. My Dell Latitude E6410 does not recognize a Epson Projector, model EMP-7800. How can I solve the problem?
Hi
you must tell the laptop to display out on the projector,
how to do that?! you must toggle the display path
Generally, there is button ( with Fn keys ) have dusplay screen sample on it, use it with Fn to toggle the display
Display have 3 modes:
  1. laptop screen
  2. outside LCD projector or monitor,
  3. or bith 1 + 2
you can press the keys 3 times ( at maximum ) to have the display on both laptop screen and projector
Good Luck
May 13, 2011 | Dell Latitude E6410 Laptop
I hooked up my Think Pad laptop to an Epson EMP-74 and the image projected is upside down. How do I fix?
Do the following for setting the screen.
1. Press the Menu button
2. Select Projection
In the Projection option,
Select Front : When the projector is in front of the
screen.
Select Front/Ceiling : When the projector is in front of the
screen and suspended from the ceiling.
Select Rear : When the projector is behind the
screen.
Select Rear/Ceiling : When the projector is behind the
ok
Apr 06, 2011 | Epson EMP-74L Multimedia Projector
No signal on epson emp-x3 projector using susb cable
I'm assuming (because of the USB) that you wish to connect a computer to the projector.
You will need a VGA cable connected to the Computer input on the projector and the VGA output on your laptop.
If it is a laptop you may have to active the external monitor on your laptop. This is generally done by pressing the function key and F5. But this will depend on your Laptop and OS on the laptop. Look for a button amongst the F keys (at the top of the keyboard) that will do this on your laptop.
Mar 21, 2011 | Epson EMP-X3 LCD Projector
LCD projector not displaying image of the laptop
On that Dell, you have to tell the laptop to display the image on an external unit--look on either F4 or F8--you will find a small TV screen symbol. You have to press and hold "alt" and press the key. The options are, 1-show image on just the laptop, 2-show the image on the laptop *and* something else, (like a projector), or 3-show an image on JUST an external display. NOTE: Sometimes, you have to turn on the projector FIRST, then immediately turn on the laptop so they boot together--just one of those strange things...(remember, **for example** first press of "alt" F4 will get you laptop and projector, second press of "alt F4 will get you JUST the projector, third press of the keys will bring you back to just the laptop)---Rick
Sep 07, 2009 | Panasonic PT LC75U Multimedia Projector
My epson LCD only shows a blue NO SIGNAL screen???
you just need to enable the 2nd monitor in display properties, right click on desktop and select properties then settings and right click on the 2nd display select attach.
or look at the keyboard press FN and look at the F1/f12 keys, one of them will turn the external display on or swap between outputs.
Jun 03, 2009 | Dell InspironTM 1501 Notebook
Screen image is distorted small using Epson EMP 821 with Latitude D620
Check Epson"s support site to see if there is a driver for the projector. Some projectors require a driver for the visual clarity, and lots of times the driver disc doesn't come with the projector, go figure, and don't ask me why.
Aug 04, 2008 | Dell Latitude D620 Notebook
Epson LCD Projector Model: EMP-S1H
Hi there. What windows are you using? There are a few different ways of chaning it but usually diferent depending on what make computer and what windows you are running, but normally on xp you can go into display and go to the advanced settings, then click on graphics setting and it gives you the option to change everything including temp, saturation etc.
Feb 01, 2008 | Office Equipment & Supplies
Acer Aspire 5610-4648 Notebook Logo
1,589 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
