Question about Casio Exilim EX-S500 Digital Camera
Casio ex-s500 i cannot find the two latches that hold the lens assembly in. do i need to remove the lcd from the back to get to them, or are they on the front side?
  • mjohns19 Mar 24, 2008
    the easiest clip to remove first is the one on the outside. then i unclipped the one on the top right under the ribons and then the entire lens assembly came out. next i removed the ribons from teh board by popping the clips up to release the ribon.
  • 477 Answers
They are on the front side once you remove the cover diconnect the ribbon cables and look at the bottom right hand corner and there is one of your clips. the other one is caddy corner to it top left of the lens. I fix them also.
Posted on Mar 12, 2008
Compact digital camera lens assembly jammed after dropping
i worked as service engineer on life support equipment for 15 years but alas my cannon g10 with above symptoms didnt make it back together .... never start without a manual to assit you ....adrian
Dec 27, 2009 | Casio Exilim EX-S500 Digital Camera
Casio ex-s500 front facade around lens has come off
My wife accidentally dropped ours and the ring popped off when it hit the floor. It does just twist back on. You just have to get it lined up just right and then it will essentially snap into place. If you don't get the ring lined up right though it will just conitinue to fall off. I've had focussing issues with mine ever since the ring came off though.
Nov 07, 2008 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-S500 Diaphragm Problem
Well, on mine the problem was inside the lens assembly. There is a ribbon wire that runs along the inside wall of the lens housing (that powers the diaphragm motor) and, as the lens is retractable and there is a zoom mechanism, it forms a loop, so it can extend and retract along with the housing. In my camera, this wire formed a crack right in the middle of that loop. The crack does not extend along the whole width yet, so in certain zoom positions there actually is an intermediate contact, so that the diaphragm actually works if you use the intermediate zoom, but does not work in max or min zoom positions.
As for fixing it, the only thing you can pretty much do is to replace the whole lens assembly. That wire is a branch of a bigger one that powers other motors in the lens, so you can't really remove it easily, and besides, no one carries it by itself. The new lens assembly is $380 from the parts supplier. So I just bought a broken camera off ebay for 9 bucks, with a functional lens. When it comes in, I'll just replace it. The replacement part is actually pretty straight forward. The lens assembly is held by 3 snap tabs, so just disconnect the wires for the CCD and the motors and remove the assembly.
Feb 18, 2008 | Casio Exilim EX-S500 Digital Camera
Casio EXILIM ZOOM EX-Z60... Problem
The power leads that are soldered from the main circuit board to the LCD are near the lens assembly ( about 7 o'clock). Did you break one of these? If so, it will need to be resoldered.
Dec 15, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio Exilim EX-S500 screen is black when turned on
you camera shutter is stuck at close position, you will need to open
the thing up to repair.
As for the totally dark screen, either your LCD or driver board is bad. You will need to open and replace the broken part.
Nov 15, 2007 | Casio Exilim EX-S500 Digital Camera
Casio ex-S500
Its a bad lens. send it in for repair or get one off ebay with a broke LCD lens should be ok .
Soft focus s500
It is a bad lens very common issue with casio send it in for repair or get one off ebay with a broke lcd lens might be sill ok.I fix these cams all the time with bad lenses.
Nov 08, 2007 | Casio Exilim EX-S500 Digital Camera
Casio EX-S500 Lens error. when i turn the camera on i get a grinding sound and the lens only comes out part of the way. from what i understand the gears in the lens must be stripped. does anyone have a...
Remove the Back and front covers, then use a small flathead screwdriver to release the 2 hinges that hole the lens assy down; then unlatch the 2 ribbons cables. Now you can install the new lens assy. If you're not going to use the "old lens assy, can I have it, please? Thanks.
Oct 25, 2007 | Casio Exilim EX-S500 Digital Camera
The lens won't come in and wont turn on.
The lens gears are stuck/stripped. The S500 has horribly soft gears. I have a nice stack of bad S500 lenses myself. Unfortunately, the lens will need to be replaced. The only cost effective option is a good used lens from a camera on eBay that maybe has a bad LCD or something.
Aug 20, 2007 | Casio Exilim EX-S500 Digital Camera
EX-S500 Casio Exilim - Lens does not full extend on camera so the picture is blurr
get the new ex-600s.. my 500s's lens wont come back in either.. i got the 2 year ultra warantee this time cause they're junk cameras but it's the best compact for about a year till it breaks
Nov 12, 2006 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
43 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
