Ensure the All-In-One printer is powered on.
Lift the scanner unit
The cartridge holder will move to the center of the All-In-One
Press down on the cartridge carrier latch to raise the carrier lid.
Remove the used cartridge.
NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge.
Remove the protective tape from the back and bottom of the new cartridge(s).
WARNING! Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges
Insert the new cartridges into their respective carriers.
Close the carrier lids so that they remain closed.
Close the scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed.The control panel display will prompt you to load paper and print an alignment page.
NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at
https://www.6ya.com/expert/joe_8b8c2cd6ce148309
