Question about Venturer (1012827) System
Venturer rvs2631 Hi I was wondering if there is any one out there who coud help with this problem.I have a rvs2631 and the vcr works fine sound and picture but the dvd picture is fine but there is very little sound. I have changed the rca cables but still the same. I would appreciate any help to rectifie this problem.
2 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: Every time i put in a vcr tape the vcr turns off what can i do?
This is probably happening because the tape loading isn't completing within the required time after you insert a tape. Either the tape isn't seating properly in the machine or something is interfering with the loading. This might be due to the tape itself, but since you've said this happens every time, that's unlikely. There may be something inside, like a piece from an old cassette. The VCR mechanism may be out of timing. There are plastic gears that need to mesh properly so that all the parts move at the right times, and these can get knocked out of sync. Or there might be an electronic problem in the power or loading circuits. There's not much you could do other than take the cover off to see if there's an obvious obstruction. Beyond that, this needs to go to someone for service, or it's time for a replacement. Given the low cost of these combo units today, replacement is the usual "fix".
Posted on May 26, 2009
1984 Yamaha Royal Star Venture XVZ 1300 tachometer not working
Hi, Anonymous and the usual suspects are:
1. Instrument wiring harness connector corroded.
2. Faulty power or ground wire at the tachometer.
3. Broken, loose or corroded tachometer wire at the coil.
4. Short between the ignition coil and the tachometer.
5. Broken tachometer cable.
6. Faulty tachometer.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Thread 1983 Venture Royale 1200 and need help
http://www.venturers.org/Tech_Library/?action=category&cat_id=001007
http://www.werder.ee/Manual/XVZ1300.pdf
https://www.partsfish.com/page/oem-parts-for-yamaha
YAMAHA XVZ1300A Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 16, 2018 | Yamaha Royal Star XVZ 1300 A Motorcycles
Rolling B&W Stripes, No Sound, in DVD Mode
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 17, 2017 | JVC Televison & Video
My 2001 chevy venture won't start
Check out this link, should help you understand why that security light is causing this problem.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Mar 06, 2012 | 2001 Chevrolet Venture
Vcr gets sound but no video. dvd works fine
it sounds like the video head is dirty and needs cleaning, buy a vcr cleaning tape and follow directions on how to clean the heads... Radio Shack should have the cleaning tape....hope this helps.
Dec 29, 2009 | Philips Magnavox DVD/VCR Dual Player
What coud be making my pipe got red hot
Hi, the pipe getting red at the header is caused by the fuel mixture being to lean or the ignition timing being too retarded. Check the induction side of the engine for air leaks and the carburettor for blockages etc. Check the ignition timing.
Hope that helps Matt...
Nov 23, 2009 | 1986 Suzuki LS 650 Savage
Technics DVD Stereo SC-DV290
never done this myself, but I would guess you take phono jacks from your TV (L & R out) and plug them into the back of the sound processor, iether VDP(AUX) or VCR(EXT) IN
then go to your remote and press (vcr(ext)/vdp(aux) repeat pressing until you hear you tv
each time you press button it should go through a selector menu
TUNER->DVD->TAPE>VCR(EXT)->VDP(AUX)
hope this helps
Feb 02, 2009 | Technics SC-DV290 System
Sony slv 715ub no stereo sound on tape playback
Hi, i have a Panasonic dmr-es30veb DVD ram recorder/VCR and i cant record one channel while watching another, as you can tell i am not at all technically minded and if you can help i would be grateful many thanks Eileen.
May 13, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Sansui tv
sounds like the tv is on the wrong sorce
Apr 12, 2008 | Televison & Video
DVD/VCR combo says no disk
I would venture a guess that you have a Panasonic DVD/VCR combo. If yes, then it is possible that the H07 error is indicative of a motor problem. The normal corrective procedure would be to replace the motor.
If indeed it is a Panasonic and the motor in question, there is a temporary workaround which is better explained here.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 09, 2008 | Televison & Video
Venturer (1012827) System Logo
139 people viewed this question
Top Venturer Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Are you a Venturer Audio Player and Recorder Expert? Answer questions, earn points and help others
