Question about JVC LT-26C31 26 in. LCD Television
Stuck in stand by
Hi the front panel on my tv seems to be locked up and the remote will also not get the set out of standby, had the problem a couple of weeks now, any help? red light on will not come out of standby
  • 4,102 Answers
Hi if turning it off at the plug for couple of hours then switching it back on dont cure the problem also check batterys in remote if this still dont work then you might have problem with video card or something relating to that or you might find that its going to be a resistor or transistor in the high voltage part of the circuit.
If you have multimeter and know how to test these compnents then you will need the schematics to follow and also need to be able to solder in any new parts you might need.
You will need the schematics so you can get any part numbers you might need let me know what you want to do ok
Posted on Feb 08, 2008
    President:
  • 1,944 Answers
Did you try disconnecting the TV from the power for a few hours to reset it?
2 Suggested Answers
  • 16 Answers
SOURCE: Stuck in stand by
I can't guarantee a solution, but your problem could be as simple as a stuck button... or as complex as damaged circuitry. Make sure you've tried unplugging it for a while before you try anything else. say 10-15min Is the "action" of your on set buttons normal? If not try working it or cleaning it. Pop it off and clean thoroughly if able. Not while plugged in! I saw a set like this where a button was stuck and it made it constantly switch sources; upon cleaning it we found what looked like a bit of cheese dip back there. Worth a look anyway!
Posted on Aug 27, 2007
Turn stand by off without remote?
If the set is turned off to standby by its remote control, you must have its remote cotnrol to power it ON. No buttons on the front panel will work at this condition.
May 16, 2012 | Televison & Video
Hitachi 42LDF30U LCD TV stuck in standby mode
Hi there mine has started doing the same thing today, on other hitachi models it is a serious fault warning, i will come back when i find out more.
Jul 07, 2010 | Hitachi Televison & Video
It wont turn on its stuck on stand by any suggestions? when we do get the tv turned on we cant knock it off or it takes hours of fiddling with the remote standby button to get it back on the tv is a...
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Let me know if you need more help or info.
Nov 05, 2009 | RCA Scenium D40W20 40" Rear Projection...
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
Plasma ps42p2sb stuck on standby
Your set needs to go in for repair this is no easy fix it yourself problem!
Jan 05, 2008 | Samsung PS42P2S 42 in. Plasma Television
JVC LT-26DF7BK won't turn on
Hi I had the same problem with my LT-26C31BJE. The TV just stuck in standby mode. If you tried to turn it on, it seemed like it tried to power up, but then reverted back to standby.
I solved it this way. I took the back off the TV (unplugged of course) and made sure all visible contacts were home (they all seemed to be). Also to the right of where the power lead enters the box there is a small fuse, 250V 6.3 W. I replaced this fuse and the TV now works fine.
Dec 27, 2007 | Televison & Video
RCA 27V412T FPA LOCK ON & REMOTE LOCK
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Oct 02, 2007 | RCA 27F530T 27" TV
Stuck in stand by
Aug 27, 2007 | JVC LT-26C31 26 in. LCD Television
Open Questions:
JVC LT-26C31 26 in. LCD Television Logo
335 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
