Trouble code E-1 sub code41 - Computers & Internet
  • Roman Bartmanski Feb 08, 2008
    Hi, It is Gestetner 2732ztd copier generic
    same as Ricoh FT5832
    Thank's
    RB
  • Roman Bartmanski Feb 12, 2008
    Hi, and thank's in pointing me in the right direction. As soon as you said " light"
    I thought of the one below the glass top, well, I took if off and found that the whole slide got knocked off the track during transport.Trouble code gone, just have some feeding problems now but nothing major.
    Thank you again.
    RB
  • 4,102 Answers
Hi could you give me more info like model number or any other info as i need it to locate the correct error code for you ok
Posted on Feb 08, 2008
  • paul proctor Feb 08, 2008
    hi ive been asking round for you about the error code your having i found out that the E-1 error code relates to aa fuse that is associated with the light but the rest of the code ive been told is going to be with a short circuit on the board more than likely to do with the light problem.
    This isnt a repair you can do yourself as you would need to be able to use multimeter and follow schematic diagrammes so you can take readings at various test points on the board its not going to be an expensive repair more than likely just bad solder joint or dry solder joint should just need resoldering let me know if you need further assistance ok
  • paul proctor Feb 12, 2008
    No worrys mate glad to offer the help keep the site in mind and also tell friends and family their are thousands of experts on the site that cover every problem you could think of thanks for using this site.
    Please could you rate the sollution many thanks in advance
Dcs 5501 trouble light
When checking troubles on DSC, *2 brings up the trouble codes and trouble light will flash after pressing *2
1=Service Required (press 1 to get sub codes)
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
5=Module Supervision
6=RF Jam Detected
7=PC5204 Low Battery
8=PC5204 AC Failure
2=Loss of AC Power
3=Telephone Line Fault
4=Failure to communicate
5=Sensor (or Zone) Fault --- Press 5 to identify zone/sensor
6=Sensor (or Zone) Tamper --- Press 6 to identify zone/sensor
7=Sensor (or Zone) Low Battery --- Press 7 to identify zone/sensor
8=Loss of Time & Date
Apr 04, 2014 | DSC Home Security
Check engine light comes on, diagnostic reading says 1810
First Character - System
The first character identifies identifies the system related to the trouble code.
  • P = Powertrain
  • B = Body
  • C = Chassis
  • U = Undefined
Second Digit - Code Type
The second digit identifies whether the code is a generic code (same on all OBD-II equpped vehicles), or a manufacturer specific code.
  • 0 = Generic (this is the digit zero -- not the letter "O")
  • 1 = Enhanced (manufacturer specific)
Third Digit - Sub-System
The third digit denotes the type of sub-system that pertains to the code
  • 1 = Emission Management (Fuel or Air)
  • 2 = Injector Circuit (Fuel or Air)
  • 3 = Ignition or Misfire
  • 4 = Emission Control
  • 5 = Vehicle Speed & Idle Control
  • 6 = Computer & Output Circuit
  • 7 = Transmission
  • 8 = Transmission
  • 9 = SAE Reserved
  • 0 = SAE Reserved
Mar 03, 2011 | Chevrolet Chevy Cars & Trucks
My dell d505 cdrom won't work looked on device manager it says the fault is a code41
The meaning of the above error code is Windows successfully loaded the device driver for this hardware but cannot find the hardware device, pls follow the steps in the below link for code 41.
http://support.microsoft.com/kb/310123 .
Hope this helped.
Jan 21, 2011 | Dell Latitude D505 Notebook
I am getting a flashin L and can't make copies?
L1 = Scanner (reading) feed trouble Scanner (reading)
L3 = Scanner (reading) return trouble Scanner (reading)
Reset method :
* Entering the simulation mode
1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
(The machine is ready for entry of the main code of simulation.)
2) Main code input by 10-key ? Start key ON
3) Sub code input by 10-key ? Start key ON
The machine enters the selected simulation mode.
Press the start key to start the operation of the selected simulation.
Main Code =(14 Used to cancel the self diag other than U2 trouble.)
Sub code = 0
* Canceling the simulation and returning to the normal mode
1) Press the clear key.
Copy SIM 14
Sep 07, 2010 | Sharp AL 800 Copier
Have a 5 year old DSC Power Series 632 Model PC 1555MX. Trouble Light came on with message #1 Any options available to me other than " Call for Service " ? Would replacing back-up Battery possibly cure...
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
6=RF Jam Detected
8=PC5204 AC Failure
2=Loss of AC Power
Aug 09, 2010 | DSC Power Supervision Relay For Smoke And...
Error code
E41 =Control board thinks the door switch is open.
1. Remove the door lock assembly and
measure the resistance of the PTC.
Shorted or open. Defective door lock assembly.
Around 1500Ohms. Defective control board
hope` this helps
Jul 26, 2010 | Frigidaire Affinity ATF7000E Front Load...
My Toshiba e161 printer error code on E 7. what problem in my printer and how the solved the problem
what is the sub code?
main code sub code description
E7- 02 LSU trouble 10 Shading trouble (Black correction) 11 Shading trouble (White correction) 12 Shading trouble 16 Abnormal laser output
more details digivisionm@gmail.com BR
Mar 09, 2010 | Toshiba e-Studio 161 Copier Copier
Sharp AR-M550 with a paper tray error F3-12
1. Start and end of simulations Note: The "PAUSE" key in the descriptions means the "INTERRUPT" key. Simulation IN The Simulation IN mode becomes only available from the Copy mode screen. In the simulation mode, printer operation is inhibited. Printer operation is also inhibited in either of the Aging mode or the Adjustment Copy mode. The printer selection key is disabled, too. By operating the keys [C] – [PAUSE] – 0/g – [PAUSE], the simulation main code input screen appears. * If the interval between any two key operations is more than 5 seconds, the entry into the simulation mode is canceled. (Ref.) 1 ~ 9: Loading/ sensor checks 10 ~ 19: Resetting troubles 20 ~ 29: Counter/mode setting 30 ~ 39: Sensor activation checks 40 ~ 59: Adjustments 60 ~ 69: Digital readout and printer Simulation OUT The simulation can be terminated by pressing the [CA] key. 2. Simulation main code input screen SIMULATION NO. _ INPUT MAIN NO. AND PRESS PRINT SWITCH 1 If any trouble has occurred when the trouble code is requested, the 7-segment readout displays the trouble code (main only). [Note] The trouble code is canceled when the copier enters the simulation IN mode. [Note] The 7-segment readout becomes blank when the copier enters the simulation IN mode. 2 Only the [PRINT] key LED comes on. [Note] The [PRINT] key LED is usually OFF. It comes on when the copier waits for the [PRINT] key to be turned ON in the simulation mode. 3 The main code input area (2 digits) waits for the input of a main code. [Numeric Key]: Main code input [Note] Codes are entered in the ring format. [PRINT]: Sets entered data. [C]: Clears entered data. [CA]: Terminates simulation. [Others]: Cancels (ignores) entered data. 4 If a simulation has a sub code, it should be executed on the sub code input screen; a simulation does not have a sub code, it should be executed on the simulation execution screen. 3. Simulation sub code input screen
Dec 08, 2009 | Sharp AR-5320 Black and White Copier
MFC-3220C Error code 41..call brother
error code41 unplug machine,then call brother
Jul 10, 2008 | Brother Office Equipment & Supplies
How I CAN CANCEL CODE U2 in sharp arm451n
This resets the code
Sim 16 sub 0 Used to cancel the self diag "U2" trouble. Cancel Trouble Error
SIMULATIONS
1. Entering the simulation mode
Enter the copy mode and perform the following procedures.
[P] [*] [C] [*] [Main code] [START] [Sub code] [START]
2. Switching the simulation mode
Press [USER SETTING] to return to the code entry screen.
3. Canceling the simulation mode
Press CA key to cancel the simulation mode.
You may need to have a tech look at this.
Hope that helps
Jun 23, 2008 | Sharp Office Equipment & Supplies
Computers & Internet Logo
53 people viewed this question
Alun Cox
David Payne
David Payne
