Question about Proton WT-3650 34" TV
ProtonPPLTV4250 TV is being installed by contractor but he can't get the base off to place it on the wall. He has called several times but the gentleman told him to pull it off but it is not working. Then we were told to go to the website and a diagram would tell us what to do, but where is the diagram? We need help now because my contractor wants to leave. HELP!
    President:
  • 4,402 Answers
Rheem model: RCFA-HM4821AC I am trying to purchase the assembly that holds the filter in place. It might be called a tray, or a rack, or a bracket, or an assembly; I do not know what it is called.
Get an HVAC contractor to take a look at it. We usually remove the blower assembly, measure the back side of the unit, a fab a piece of 90° metal to help retain the air filter down. Like a shelf bracket that runs the legnth of the back side. The original installer didn't use a filter base. The unit sits on top of it and it's easy to change the filter. You can fabricate 1, or possibly find a pc. at a hardware store. Thin 90 degree metal. Hope this helps!
Mar 30, 2017 | Filter Heating & Cooling
Was this job done properly, and if not, then how really bad it is? I would rather hire the same person again, but not if the previous job is completely wrong ?
Some times new specs come into force. some things that were ok five years ago will not pass to day. can you get a gas inspector to check it over ? then go with his advice. It appears you have two Quotes , So why not get one from the person who installed it if you would rather him do the installation .
Mar 03, 2016 | Ruud RGTM10ERBJS 100K BTU 95%...
I have narrow bullnose guttering on sides of metal roof. there are no down pipes attached. Water is leaking into bedroom and dripping down wall when it rains.
I strongly advise you call a contractor listed on Home Advisor Pro com. You will get several options for screened roofing contractors looking of work like yours. Your situation needs an experienced eye to visually inspect and determine the source/cause of the leak. There is no obligation or cost to you for using that service. The contractors pay for leads like yours.
Jan 07, 2015 | Cars & Trucks
My Uniden TRU8885 will no longer give a dial tone or ring when called (I tried using my cell phone). All associated handsets are similarly afflicted. Cleaning peope were here today and must have pressed...
The TRU8885 has a Do Not Disturb feature which will disable the ring on the base and all handsets. To toggle this off, press and hold the DND button on the base. (The key is on the lower left of the keypad, next to the * key). The answering system will turn on when the DND feature is enabled, if it wasn't previously on.
However, this shouldn't disable the dial tone when you call out. I suggest that you check that the base has power. After that, you have to look for a wiring problem. The problem could be the phone, the RJ-11 cable between the base and the wall jack, a wire that is damaged in the wall, or an outside line problem.
First try a new RJ-11 cable; make sure not to use a wired handset cord. After that, I like to use an old corded phone that requires no power adapter to test the line. If the test phone gets a dial tone, then the TRU8885 base has a problem. If the test phone doesn't hear a dial tone, try plugging it into another jack on the phone line if possible. If there's no dial tone (or no other jack), find the incoming service box. If there is an RJ-11 plug in the box, check for a dial tone there.
If you have no dial tone at the service box or can't test the line at the box, contact your telephone company. Most companies will check the line and fix outside problems for free. If the problem is at the first jack, remove the cover plate and look for a loose wire. There are two styles of RJ-11 jacks. The screw terminal type require you to strip the wire and secure it under the correct screw. For the keystone jack type, you do not strip the wire. You use a punch-down tool (available at many hardware stores in the electrical section) to push the wire back into the correct section of the keystone. The little pins will puncture the insulation when the wire is properly inserted to make the connection. See http://www.lanshack.com/wire_phone_jack.aspx for the connection wiring connections. If you have an DSL filter inside your home, replace it if it is faulty. For any other inside wiring problem, you may want to let a professional find the wiring break in the walls. Your phone company will do this for a fee.
I hope this helps.
(I have had dial tone issues from several different causes. A single jack's wire was left disconnected after a service upgrade. Several outages were from damaged outside wiring either from mice chewing or a contractor digging through the wire. With a DSL line, the lightning strike damaged the filter and blocked all of the signals. Recently, a fiber-optic service card failed resulting in intermittent dial tone failures. Except for the first issue which I could fix myself, the local phone company or appropriate contractors fixed the issue for free. However, I don't live in an area where the phone company is trying to stop serving some wired phone customers.)
Dec 29, 2017 | Uniden TRU8885 Digital Answering Machine
How do i remove the stand/base off a panasonic viera TX37LZD70 37" flat screen tv so I can wall mount it?
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Jan 07, 2011 | Panasonic Televison & Video
Who or what number do I call if the flat screen 32" hdtv I purchased under a year ago is missing the neck to the stand? I had placed it on a wall mount upon purchase and never realized the stand was...
Missing thing hard to claim incomplete,because of a long period times.U can try the place where u buy this tv or the 1800-??????? in ur instructional owner manual.Talk to their costomer service.
Sep 21, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Remove base to wall mount
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: http://www.managemylife.com/mmh/owner_manuals/search?query=LC46SB54U+ .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Sep 16, 2010 | Sharp LC46SB54U 46 in. LCD TV
Correct vinyl window installation
vinyle or no vinly, windows frame should be secured to the frame. The vinyl windows should have flange used to secured the windows to the outside wall if not to the frame. Looks like "CSE" didn't do a good job securing the windows. do you have trim on the outside? what knid of clualking? good thing is nothing happen in the last 3 years.
Since your contractor secured the windows to the frame, then you need to make sure all screw heads are protected and he did not make any unnecessary holes. all holes should be filled.
Jun 05, 2009 | Home
43FDX10B working Great until Time Warner installed cable box
try connecting the box to a different input
also try connecting another device (like a VCR) in place of the box to see if the problem exists without the cable box
Jan 13, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Proton WT-3650 34" TV Logo
48 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
