Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer LGR5636PQ0
My dryer will not heat and will not cut off after a cycle. I've checked Cycling thermostat and thermal fuse and both have continuity. Could the problem be my ignitor. The dryer is gas
  • Gary Davd
    Gary Davd May 11, 2010
    is the ignitor glowing??
I replaced the heating element and had the old one checked and had the thermastat's checked as well and it still does the same thing, will not blow hot air and will not cut off when cycle is supose to be finished, what should I do?
Posted on Feb 21, 2008
2 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: LGR5636PQ0 Whirlpool Dryer has no heat
Possibly there's a problem on the coils inside that why it can't suppy the heat to the surface. Even the thermal fuse is ok but the coils supplying never responding to give such heat.
Posted on Feb 10, 2008
My whirlpool dryer LER4634PQ0Runs but doesnt heat up?
It could be a number of things, but i would start with these first:
THERMAL FUSE.
The thermal fuse is designed to prevent the dryer from overheating. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
There are also a couple of 'thermostats' that could be the problem:
The 'high limit thermostat' is a safety device mounted on the heating chamber and is designed to prevent the dryer from overheating when the exhaust vent is restricted. A restricted vent will cause the high limit thermostat to trip or activate, interrupting the circuit to the heating element or gas valve. The high limit thermostat is not designed to activate repeatedly like a cycling thermostat and will eventually fail causing a no heat symptom. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter. If there is no continuity then it will need to be replaced and the restricted vent system corrected as well.
OR:
Cycling thermostats control the temperature inside the dryer drum. They are designed to "cycle" the heating element on and off to maintain the correct amount of heat. Cycling thermostats are normally located on the blower housing or elsewhere in the internal airflow ducting. Over time, the cycling thermostat can become defective. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter.
I hope this helps you fix the problem.
Dec 02, 2013 | Whirlpool LER4634PQ Electric Dryer
Feb 10, 2008 | Maytag Neptune MDG5500AW Gas Dryer
I have a Whirlpool electric dryer M/ WEP5300o that will not heat. I have replaced the Cycling Thermostat, High limit thermostat, Thermal fuse and heating element. It still doesn't heat. There are
If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Feb 02, 2013 | Whirlpool Dryers
I have duet dryer GEW 9250PW0 with no heat. I have changed Thermister, Thermal cut off, high limit thermostat, heating element, and main board. I've check pwer cord and oulet and they check fine
You didn't mention checking the "cycling thermostat".
The two large terminals will be closed, and the two small ones should ohm out around 250 ohms. You also need to check and make sure you have 240 volts coming to the dryer. You could have one of the two breakers thrown. Here is the cycling thermostat in case you find it bad.
Keep me posted on your findings.
Oct 22, 2012 | Whirlpool GEW9250 Electric Dryer
Does the Kenmore Series 700 dryer use circuit breakers or a thermal fuse to shutoff the heating element?
All Kenmore Electric Dryers use a thermal cut-off or thermal cut-out, hi-limit thermostat, and a cycling thermostat apart from the motor centrifugal switch as parts of the heating circuit. The thermal cut-off/thermal cut-out and the hi-limit thermostat are located on the heater duct/element duct while the cycling thermostat is located on the blower housing.
The thermal cut-off/cut-out serves as a safety measure and blows open should the dryer overheats or should the hi-limit thermostat fails to cut off power to the heating element. Check the continuity of the thermal cut-off/cut-out and if open, replace it including the hi-limit thermostat.
Aug 22, 2011 | Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
Dryer goes on and spins but no heat. I've opened up the back but what now? Is there a specific part that if blown would cut off the heat? Model is a small one - probably cost about $300 - don't know the...
The thermal cut-off at the top of the heater duct/housing blows when the high-limit thermostat below it fails to cycle the heating element on and off properly to regulate the heater temperature. This thermal cut-off along with high-limit thermostat including the cycling thermostat on the blower housing are wired in series with the heating element and power to it is cut when the thermal cut-off blows as a safety feature to prevent fire. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 11, 2011 | Roper REX4634KQ Electric Dryer
No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
My dryer is not heating up, I did replace fuse but sstill no heat
The thermal fuse is not a part of the heating circuit which is composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on link below for the detailed troubleshooting and repair.
Feb 21, 2011 | Dryers
Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
Feb 12, 2011 | Dryers
Whirlpool LER5636P Electric Dryer Logo
202 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
