Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi Ultravision Digital TV Model 57SWX20B
Help! Our TV had a stroke! My guess is that the blue bulb is the sickie of the bunch. The blue lines are not lined up, they are sagging down the screen, so we are seeing yellow straight words with a saggy blue double, and people have nice yellow blotches on their faces and their teeth are green. Actually quite comical, but does need to be fixed, as it is a little annoying to watch for any extended period of time. Do we simply need to replace our blue bulb, or is this some sort of other problem? We have done many Magic Focus's on it, most of the time it will not focus and get's stuck on the blue, however from time to time, we can get it to focus and look right for about 5 minutes then it strokes out again. Can you help?
  • 3 more comments
  • KnittyChick Feb 08, 2008
    It looks like this.
  • Anonymous Jan 23, 2009
    the top of the tv is saging and the color is off looks like maybe green or blue color tubs
  • Anonymous Feb 03, 2009
    i have same but it red i like to fix it myself i need someone to tell me how?
  • ducky9 Feb 10, 2009
    I am having the same problem with mine, except the blue is off allignment about a 1half inch to the right vertically. I have tried the magic focus numerous times. When the focus gets to the blue screen, it does not finish. Its like it starts but does not finish. What can I do?????
    Please Help!!!! Thank you, Matt Lucas
  • Anonymous May 14, 2009
    red color is sagging and the magix focus both auto and mannual do not help the problem? What do I need to do to fix it?
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Feb 08, 2008
How can i get picture and picture?
Posted on Feb 20, 2009
Why my t.v screen is one inch less from down side?
Vertical scan output section circuit fault.
Visit this site to get more details.
Feb 19, 2015 | Televison & Video
How to replace fuel lines craftsman 316.292620
Initially release any clips by squeezing with a pliers and pushing back along the line. Lines can be prised off using a snipe nose pliers or flat blade screw driver, pushing on the edge of the line. Don't pull the lines which can stretch them.Two fuel lines leave the tank of a two stroke engine. The primer bulb sucks gas from the tank via the line with the filter on the end, gas returns to the tank via the other line without the filter. When you replace a line, to check whether they haven't been mixed up, fill the tank but leave the line without the filter above the level of the gas. When you push the primer bulb, gas should eventually squirt out the line without the filter. If the lines are mixed up, air bubbles will flow out of the filter and no gas out the other line.
For a pictorial guide and more info on troubleshooting 2-stroke engines and carburetors, see my guide here:
String Trimmer Won Work 2 Stroke Engine and Carburetor Troubleshooting
May 14, 2014 | Homelite Mighty Lite Lawn Trimmer
My LG 42 Plasma works sometimes then half the screen goes black but the right side stays perfect???
have almost the same problem left side is black with sometime blue line red lines or a whole bunch of different lines some one help please have sound and right side of tv works fine
Sep 26, 2010 | LG 42PC3D 42 in. Plasma Television
Blue lines on screen...
Try Encompass Parts 1-800-638-3328
Dec 14, 2009 | Televison & Video
My screen has a blue line that sags from the left side to the right. It is in the top 3rd of the screen. It is not a single thin line.
Your TV has bad convergence IC's. This problem needs a professional Tech to replace these parts. The average cost should be around $450. Call a factory authorized dealer.
Thanks for visiting FixYa, Big Irish.
Nov 21, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Samsung Projection tv Blue line across the screen curving up
This set does not have a bulb. It is a tube type projection set that sounds like it has a convergence problem. Call a qualified tv repair company.
Jun 24, 2008 | Samsung - Projection TV replacement lamp...
Hitachi 46f500 convergence?
a common problem wich i also have with convergence with blue and red convergence.
the image converge amplifiers are burnet out wich in turn blow out resisters that control individual color convergence.
Jun 19, 2008 | Hitachi 46F500 46" Rear Projection...
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
May 21, 2007 | Toshiba 43H70 43" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
2,580 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
