Question about Texas Instruments TI-30 XIIS Calculator
2x-3 =-7 how do i enter the = sign on the calculator to solve the problem
    Problem Solver:
  • 13 Answers
Use the exe key
Posted on Feb 08, 2008
How to find the polynomial roots in TI-83 Plus
One way is to use the Polynomial Root Finder and Simultaneous Equation Solver app.
Press the APPS key, then select PlySmlt2 and press ENTER. Press ENTER to get past the opening screen, then select "POLY ROOT FINDER" and press ENTER. Select the order of the polynomial and other settings as desired. Press F5 (the GRAPH key) to go to the next screen. Enter the polynomial coefficients, then press F5 to solve. The next screen will show you the roots (unless you selected real roots and the polynomial doesn't have any real roots).
If you don't have the app installed, you can download it from
http://education.ti.com/educationportal/sites/US/productDetail/us_poly_83_84.html
Jan 20, 2011 | Texas Instruments TI-83 Plus Calculator
I don't know how to solve for x. For example. I type 22x=22. The answer it gives is 0. On all problems x is zero
The variables you have at your disposal in this calculator are
A, B,C,D,X,Y,M. All of them are accessed by pressing the [ALPHA] key before the key near which is written the name of the variable. You will notice that the markings of the symbols accessed with the [ALPHA] key are of the same color as that of the [ALPHA] key.
You will notice also that there are two = signs.
The one at the bottom right executes the command line. By pressing it you find the result of the expression just entered.
The other = sign is marked on the body of the calculator with the same color as the [ALPHA] key. It is located at the top left of the keyboard (excluding the row with SHIFT, MODE, the navigation buttons)
Example to enter X^2-2X-35=0 you proceed as follows.
Direct access physical keys are in [ ],
[ALPHA] (X) [X to power 2] [ - ] [2] [ * ][ALPHA][(X) [ - ] [3][5] [ALPHA] (=) [0]
Usually when you enter such an expression it is with the intention of solving it for X. By default X is taken to be the UNKNOWN. You will be prompted to enter the value assigned to any other letter symbol (Y, A,B,C,D).
So, if you want to use the Solve function, you enter the equation you are dealing with, and before pressing anything else, press [SHIFT] [CALC] and the calculator will ask you a question: "Solve for X?" , and you press the = sign at the bottom right.
Then you will be prompted for any other non-X letter. Once all non-X variables (if any) are given values, the calculator will return with the solution. You will see on the screen L-R= (should be zero if you are lucky).
Nov 16, 2010 | Casio FX-115ES Scientific Calculator
Graph y1 = 2x +1 if -1< x< 0
Graph 2X PLUS 1 for X in open interval ]-1,0[
It should be entered as follows
(2X plus 1) (X larger than negative 1) (X less than zero)
In [Y=] editor and on line Y1= type your right hand side between parentheses (2X Plus 1). I use the Plus instead of the usual sign because the parser of the web site removes the sign.
[( ]2 [X,T,theta,n] [Plus] 1 [)] [(] [X,T,theta,n] [2nd][MATH] [3: larger than] [(-)] 1 [)] [(] [X,T,Theta,n] [2nd][MATH][5: less than] 0 [)]
Here are some screen captures to help you
Oct 30, 2010 | Texas Instruments TI-84 Plus Calculator
How do I use the calculator to get x and y in variables?
Sep 07, 2010 | Casio fx-300ES Calculator
How to use the calculator to solve simple equations?
Sep 05, 2010 | Casio FX-115ES Scientific Calculator
How do i enter the equation 5x-3=11+12x how do i enter quadratic equation x squared -2-35=0
Example to enter X^2-2X-35=0 (not your expression)
So, if you want to use the Solve function, you press [SHIFT] [CALC] and the calculator will ask you a question: "Solve for X?" , and you press the = sign at the bottom right.
Jul 31, 2010 | Casio FX-115ES Scientific Calculator
How do you enter or solve for x? ex: 4/5 x = 6
Take the time to read the whole post. It explains the use of variables on the calculator. The use of the solve( function is at the end of the post.
May 14, 2010 | Casio fx-300ES Calculator
-2[3x-5 (2x-3)]=3x-8 how do I do the brackets and the equal sign in this equation? When I try to use the regular = sign in the bottom right I get a syntax error?
Use the other = sign obtained by pressing [ALPHA][CALC]. You also use the[ALPHA] key before entering X,Y,A,B,C.D variables.
The = sign at the bottom that gave you syntax errors is in fact an EXECUTE command. It used to be marked [EXE] on Casio calculators
Mar 04, 2010 | Casio FX-115ES Scientific Calculator
For instance if I have a problem of 4x+1-x=2x-13+5. how do I enter it in my T E to find wha is X
This calculator does not have a Solve function or a solver. However this example of yours is very simple that you can do it by hand. If you do not mind I will show you how to solve it. Not everything needs a calculator.
You want to solve for x. OK
  1. Start by gathering similar terms 4x-x =3x; -13+5 =-8
  2. Rewrite your equation as 3x+1=2x-8
  3. Make the +1 change side while changing its sign
  4. 4x+1 -1 = 2x-8 -1 or 4x=2x-9
  5. Make +2x on the Right hand side go to the left hand side, changing its sign in the process 4x-2x=-9 or 2x=-9
  6. Divide both members by 2. This gives
  7. x=-9/2 or -4.5 if a decimal result is required.
Hope it helps.
Dec 06, 2009 | Texas Instruments TI-30XA Calculator
Inputing factors on a casio fx-115es calculator
Unless I am failing to understand your problem, just combine like terms to get:
9x^2+2x+4 and then enter those coefficients into the quadratic solver.
That will get you the two answers -- both of them will be complex.
If you wanted to turn those two answers into factors (complex) of the original equation simply
change the signs on each and put an x in front.
Of course, the quadratic formula would also work.
CG
Apr 17, 2009 | Casio FX-115ES Scientific Calculator
Texas Instruments TI-30 XIIS Calculator Logo
48 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
