FrancisFrancis! FrancisFrancis! X1 - Stainless Steel Espresso Machine
Problem for FrancisFrancis! FrancisFrancis! X1 - Stainless Steel...
Francis Francis
By mandeelion on Feb 08, 2008
I am having problems with my francis francis getting to temperature. I want to know where I can buy parts. I called illy on the east coast and they will not sell parts and it will cost too much money to ship it for repair. Does anyone know?
Clarification Request
Posted by flashfreaker on May 03, 2009
Does anyone have pictures of the wiring inside of the X1? I'm 99% certain I have my wiring correct, but I want to confirm. Thanks in advance!
Same Problem
May 04, 2009
-   My boiler top blew on my X3. May be a thermo issue that caused it, but I need to get it operational before I can further diagnos it. I need a new boiler top half, but am having trouble locating the part. Bill922- if your offer still holds, I would love your X3 for parts. Thanks Alex (azaslov@yahoo.com)-   azaslov
Jan 07, 2009
-   My X3 is getting too hot, so I ordered a new thermostat from Chris Coffee. But it's not an exact fit. There is a round flange soldered to the upper part of the bulb that seals it in the boiler. Has anyone else found a solution for this? -   joe1030
Dec 01, 2008
-   I have owned the FrancisFrancis X1 for one month. I noticed that the pump pressure is no longer what it used to be and the espresso tastes different. It used to make a popping sound from the pressure when I released the handle to remove the pod. My machine stopped doing this today. The coffee tastes different. I changed the O ring seal, but am still having the same problem. I am a little worried after reading a few posts. It seems like the machine is giving a few people problems.
Any suggestions? -   elwoodsantia
Nov 12, 2008
-   hi i have the same problem also, my X1 is about 5 years old and has just stopped heating the water it only rises to to about 50 or 60 degrees, i live in ireland so does any one know where I might get it fixed? suspect the element is dead but might try the thermostat, how can I identify the thermostat?
thanks james-   ballyc
Oct 26, 2008
-   Too bad that a good espresso maker is made by scam artists. Does anyone want my X3 for parts? The heating element is obviously shot.
Thanks to posters who have kept me from sending my machine in at much expense. Avoid the Francis Francis brand!
-   bill922
Best Solution
posted on Jun 12, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
On the contrary I have had a wonderful expirence with Illy repair service (Empire Fulfillment). They fixed my machine within two days! I had a hole in my boiler and they fixed it along with the temp gauge which was broken. I talked to two different people from Empire Fulfillment and they were very helpful and they even called me after my repair as a follow up call to make the machine was up and running. They were Great with their customer service.
TH
Solution #2
posted on Aug 24, 2008
Helpful)
allan50
Rank: Apprentice
Rating: 86%, 6 votes
After reading a number of posts on this forum regarding the difficulty of obtaining parts for the XI, I began to research to see if there are any compatible parts to repair my burned out heating element. The element heats the water in the brass boiler and would be one of the main reasons for no hot water. My machine broke with sparks flying due to the connection burning off and allowing the cable to touch an interior part of the machine.
I managed to repair the X1 by bringing the broken element to an espresso repair outlet who compared my element to an almost identical one used in a Saaco machine. I have attached a photo.
You need to be aware that although the parts look identical, the fittings at the top of each element are must a millimeter or so larger than the original part. This means that the fitting will not fit the top of the boiler without drilling the existing holes that both the fittings fit through slightly. This is not difficult if you have a drill and a 15/16ths drill bit. The boiler is brass and the metal is soft. You need to make sure if you choose to do this, that the holes are drilled cleanly. Take photos prior to make sure you re-install everything back correctly if you can not remember.
The part number for the Saaco is MCP 42 07. The element is 120 Volts and 900 Watts. The original X1 element is 1000 watts but I have not noticed any difference in performance or heat time.
Comments:
Aug 24, 2008
New Saaco element on the left. X1 element with burned out connector on the right. Note the slight difference in the width of the threaded fittings on the Saaco element (slightly larger)
Aug 24, 2008
- Lastly, should you choose to try the Saaco element, please be sure to purchase the appropriate lock nuts for the new element aswell as new rubber washer-gaskets for the threaded portion of each element (2). The old lock nuts and gaskets will not work on the new part. Also, mistake made on the sixe of drill bit. Drill bit should be 15/32ths in.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on May 02, 2008
Helpful)
jtca
Rank: Apprentice
Rating: 87%, 11 votes
For heating problems, it typically is the thermostat which in my X3 turned out to be a Prodigy Italiana TR/86. After much searching, I discovered that Chris' Coffee Service sells the same thermostat for use in the Isomac Zaffiro here: http://www.chriscoffee.com/products/home/isomacparts/zaffirothermostat
When you go to install it in the X3 you may need to omit the temperature control knob as was the case with the original installed in my X3. Also note that the P2 wire connector lug goes unused in the Francis Francis X3 (they actually cut it off in the OEM installation), but may get used in other models... not sure. Also note that these type of thermostats are mechanical in nature and can stick open or closed in some occassions. Try opening your machine and tapping on the thermostat to attempt to free it so it moves properly again. Good Luck!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Jun 30, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
buttsecks does the trick. (My illy exploded from steam build up in the hose bit.
Solution #5
posted on Oct 12, 2009
Very Helpful)
andyandrews3
Rank: Guide
Rating: 88%, 2 votes
The above comment saying to order from Chris' coffe is WRONG. I just lost $46 because the thermostat is not an exact replacement. Now I find out YOU CAN ORDER THE PART FROM EMPIRE FULFILLMENT. I just got off the phone, the guy offered to email a wiring diagram to make sure it was the right part for my X3. I ordered the part, it cost EXACTLY the same amount as the WRONG PART from Chris' coffee. The issue with having with having to send in your machine is a RED HERRING. Boys and girls, you should know, electrical parts are NOT RETURNABLE. The guy at Empire Fulfillment says they ask for the unit to be returned or if the boy/girl does not understand that Electrical parts cannot be returned! So if you know exactly the part you need, it MAY BE ORDERED by calling 1-877-854-4141.
Comments:
Oct 23, 2009
- 1-877-854-4141
Was this helpful?
Yes
No
Solution #6
posted on Apr 07, 2009
Very Helpful)
dgaulait
Rank: Apprentice
Rating: 100%, 1 votes
You can order Francis Francis parts from Cafe West Distribution. I discovered this by calling Illy USA. Their service is terrible but they do have parts.
Was this helpful?
Yes
No
Solution #7
posted on Sep 01, 2008
Very Helpful)
Spants
Rank: Guide
Rating: 92%, 22 votes
@allan50: that was precisely the info I was looking for when Google took me here. My element failed by corrosion. Eerily, the machine keeps working when this happens, due to what I would term a serious design-flaw. Why? It's the neutral, and not the hot side of the power supply that gets interrupted by the thermostat in this design, leaving the hot side routed right on through the heating circuit until it can't get back to neutral- or ground, as the case may be...so to speak. When the element corrodes through within the boiler, yet remains intact electrically (as it had done in my case, who knows for how long) it uses the third wire (the GROUND, which should NEVER carry any current normally) as an alternative to neutral. Hence, the thermostat is unable to regulate anything under these circumstances! I thought my t'stat had failed, but it is actually still OK. The only thing that stops the unit from getting all Vesuvius on you then is the cheapo snap-disc hi-temp cutout. This is the only thermal-cutout on the hot side of the line, period.
I'm not sure if my X5 is UL-listed, but it would seem to me this design should never have passed. It wouldn't have been so hard to put all switching on the hot side of the line for safety.
I'll finish by piling on WRT "Empire Fulfillment." (Now THERE is truth in advertising, eh?) If these guys repaired cars, you'd have to send your car into the dealer and leave it for a week for a wiper-blade replacement. I will not buy another espresso maker from Francis-Francis (or anyone else) without finding out whether I can buy whatever parts I want to do my own repairs. I don't need to fulfill anyone's empire, thankyou very much.
Was this helpful?
Yes
No
Solution #8
posted on Aug 26, 2008
Very Helpful)
coffeeDrip
Rank: Apprentice
Hi, So I'm back on the boards with another Illy Francis problem. Now the water pump doesn't suck in water. This is after the boiler broke and had to send it in to get it fixed. So I'm just here to say that I am fed up with this machine and all its problems within 1 year of purchase. Also, you can NOT get parts for this machine in the states. I already tried, and you HAVE to use only ONE service company for repairs - Empire Fulfillment. THEY ARE HORRIBLE. Because they are the only ones that can fix your machine the repair jobs are VERY costly and on top of shipping costs it adds up.... AND it takes forever for the turnaround. Don't believe any positive posts about the customer service of illy or Empire. Just do a google or Amazon search for some of the horror stories. So yea, I'm sure my water pump problem cant be fixed and there's no way in hell I'm sending this machine to get repaired AGAIN. if you are thinking about buying illy - DON'T. If you are thinking about getting it repaired by Empire, consider buying another non-illy machine
Was this helpful?
Yes
No
Solution #9
posted on Oct 23, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I lost the pieces that go with my X5 machine, the holders you put the coffee in. Where can I order new ones?
Popular Solutions for FrancisFrancis!
Questions and Unsolved Problems for FrancisFrancis!
Do you recommend FrancisFrancis! FrancisFrancis! X1 - Stainless Steel Espresso Machine?
Answer
Answer
My Francis Francis is blowing the GFI outlet as soon as it is switched ON. If I remove the wires to... (More)
Answer
how do I clean my francisfrancis machine all the way through . It's a bit old and hasn't been used... (More)
Answer
I have an old version of X1 (made in Nov. 2000) which needs a rubber seal replacement. How can I get... (More)
Answer
where can I but spare parts for a francis francis coffee machine
9 Other Users Have The Same Problem - Continued
Comment by lesliehills, posted on Sep 28, 2008
This morning after some months of easy use, the water did not heat. I switched it off for a bit. Now its heating but very very slowly - it's been on for half an hour and is at 60. Help please. I'm in Scotland, I have an X1
Comment by Guest, posted on May 26, 2008
I am having problems finding parts also, specifically the small round " screen" that the water goes through before it enters the coffee basket. Illy will not provide parts. This is a simple part to replace (it only lasts about one year before rusting to bits) and I had had to send it back to Illly twice at significant expense to have this replaced.Does anyone know of someone that sells parts for Francis Francis (X5 in this case)
Comment by ethan67, posted on Apr 01, 2008
The temperature dial on my X1 has stopped working and they won't send/sell me a replacement due to their "contract with Illy", nor will they sell parts to repair shops for the same reason. I've been told that turnaround time for repairs, if you choose to ship it back to the East Coast is 8 weeks at minimum.
This is very poor customer service on the part of Illy.
Comment by tkj10023, posted on Mar 04, 2008
We are looking for a replacement filter basket (for the ESE pod) for my Francis Francis X3 machine. Do you know where I can order one?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
in , CO
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
