Question about Panasonic PT-53WX42 53" Rear Projection Television
IC4011 INDICATED CIRCUIT FAILURE
I need more help with this problem. Does anyone have model specific experience that can guide me to this transistor and cap? Are there any other parts I should change? If I had a list of cheep parts I could order and change all of them. There is no noticable damage to the board. posted by Rhino-AE on Feb 08, 2008 Report abuse
No Video or Sound. Power Light Blinks 5 times = IC4011. Where do I go from here?
Still need a solution for this problem?
Try our Premium Assistance plan
Solution #1 posted on Feb 08, 2008
ladywinn
Rank: Wiz
Rating: 84%, 73 votes
Add to Buddies Check your hori out put transistor NTE2973 & 1200pf & 2kv capacitor next to it,most of the time this is what is bad .
ThankYou for using FixYa. Have a Nice Day.
  • Anonymous Feb 13, 2008
    I have a similar problem but before it blinks 5 times it blinks 4 times once then 5 times. Any suggestions
    President:
  • 4,402 Answers
This trans sister and cap is going to be close to the hot which is high voltage be careful !!!!! the hot is a big red some times black with red thick wires, the transistor will have a silver(or black) heat sink with this larger transistor attached to it. the cap is going to be right by it
Posted on Feb 22, 2008
How do u take aspart\dismantleb an epsion xp410?
Without knowing what previous experience of doing anything like this you have (nor tools), it would be unwise to even attempt to help guide you, as it's not a simple case of dismantling, there are many procedures that cannot be recommended to be attempted by anyone with very limited knowledge of how some specific parts are assembled. It would be much easier (although not guaranteed advisable for reasons mentioned) if you first indicated what it is you are trying to achieve. Some parts can be dismantled but most should be left well alone. Because that specific model is inexpensive, it could be much cheaper to simply get a new one as that would almost certainly be cheaper than any repair - and there are many similar models by Epson, all giving at least a year's warranty. Anyway - why not reply explaining what you are trying to do with the printer you have.
Dec 06, 2014 | Office Equipment & Supplies
Powers on blue screen,no picture,some red lines virtical yellow back round,where is the reset button ?model WD62526 HDMI.
You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections.
The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad.
This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced.
The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
Hi,you might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections.
Vertical amp chip needs re soldering.--- very common !
Vertical amp chip has failed and needs replacing !
Failure of electrolytic capacitors in vertical circuit
Failure of resisters that supply volts to the vertical circuit
Failure of deflection yoke ( not very common )
Also it might be a convergence board failure. Changing one board will not necessarily fix it. It is recommended to change all 3 boards in the unit. many try this as a DIY and fall afoul because it is a specialist job to retune and reset the parameters. The cost then becomes greater than if a tech did it correctly the first time. Be advised it is not a simple DIY.It requires soldering and desoldering skills, specialized tools and a knowledge of circuit diagrams.
Please rate my help++++Thanks for using FIXYA
Jul 18, 2011 | Mitsubishi WD-62526 Projection TV
There are green wavy lines and color distortion on my sony KP-51WS510 TV set
Jul 18, 2011 | Sony KP-51WS510 51" Rear Projection...
Tv has blue lines
Jul 18, 2011 | Sony Televison & Video
How do you rectify horizontal lines on top of tv screen??
Jul 11, 2011 | LG 42LC2D 42 in. LCD HDTV
Vertical lines
Jul 07, 2011 | Dell Televison & Video
I need circuit diagram of philips radio transistor model rd 143289-90
I need a circuit diagram for Philips Radio Model B4CA49T 1965 model can anyone suggest me where can I get it
Jan 13, 2011 | Philips Audio Players & Recorders
Oven has indicated F9. What does that mean?
An F-9 code on virtually all makes and models is related to a door latch circuit failure. While in bake, broil and off modes the board needs to see the latch unlocked. In the self clean cycle, the board needs to see the door latch in a locked position. The specific model will determine whether your range has a mechanical or motorized latch mechanism.
Oct 23, 2009 | Ovens
Ba71f0f01042 power board blows fuse
I'm not too familar with this model, but to give you some pointers, you will find when you have this problem the fuse will go straight away as there will be some of the semi-conductors short circuited. Check your bridge rectifier diodes & also the chopper transistor in the power supply. As a general check, test most of the diodes & power transistors & replace any that read short circuit on your meter. Hope this may help you as a guide line.
Aug 01, 2009 | Emerson EWL3706 37 in. LCD Television
I have an old cs 800 commercial amp side b is dead and side a comes on for a second then goes off. i want to fix it.
There are a number of variants to this model. How old is it? Also, do you have any experience with repair work? There measurements that need to be taken inside that can be dangerous. If you can, check for shorted output transistors first. That is the most common failure. ALso, there are some other common problems that I will detail later after looking the specifics up. Please update this with your experience level and we'll attempt to get this working for you.
Dan
Jun 24, 2008 | Audio Players & Recorders
Panasonic PT-53WX42 53" Rear Projection Television Logo
379 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
