From the manual...
Setting Time
1 In the Clock priority mode, press and hold TITLE for at least 2 seconds while the time is displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours while the time indication is blinking.
3 When the hour has been adjusted, press the Rotary encoder.
4 Turn the Rotary encoder to adjust the minutes while the time indication is blinking. The time is automatically set 5 seconds after the minute adjustment. The time can also be manually set by pressing the Rotary encoder.
• To synchronize the clock to another clock/watch or radio time announcement, press and hold the Rotary encoder for at least 2 seconds after setting the “hour.” Minutes will reset to 00. If the display shows over “30” minutes when you do this, the time will advance one hour.
Testimonial: "Thanks a bunch. We can now tell time in our car. LOL"
I also had some problems to figure out how to set the time, but here is the sollution i came up with:
1. Press "Clock/Timer" until a clock and "on" starts to flash in the display.
2. Turn the "volume/caleido jog" to choose which function you want to set (alarm on/alarm off/time).
3. Press "clock/timer" again.
4. Change time with the volume wheel.
5. Press "clock/timer" when you are finished.
