Laser printing problems
Our OKIDATA C9200 Laser Printer is outputting prints that are weak in color and there is streaking. We have installed new toner cartridges and a new imaging head. There was some improvement, but still the prints are not as good as they should be.
Can anyone help?
  • deedawg Oct 27, 2008
    I have been living with this problem since I purchased the unit.  It has always had streaks on the right side of color copies.  I typically only use black/white images so this wasn't a problem, but now I need nice color copies.
  • 103 Answers
Hi Gene,
Hope this will give you hints. If you could possibly acccess and print the machine diagnostic or record counters by pressing combination buttons from Off to On mode, please check the drums life and other counter records. On more complex problem with this type of printing output involves high voltage section circuit, fuser and developer.
Best regards,
Posted on Feb 09, 2008
My Ricoh 3500 color printer no longer is printing in color--just greys. It does not seem to be a problem with the color cartridges. Also, it streaks from left to right across a page from light to lighter...
The streaking could be anything internal to the printer, such as the transfer belt or a drum unit. As for the lack of color, that sounds like it is a setting in the print driver that got changed from printing in color to printing in monochrome or grayscale. Look through your print driver settings to see if you can locate this setting and change it back to color. Also, once you print in color again you may notice that the streaking is a specific color, which will help to troubleshoot that issue.
Jul 02, 2010 | Ricoh Aficio CL3500N Laser Printer
MFC-9440 CN Laser Printer is producing vertical color line streak
Colored vertical streaks - looks like a transfer belt problem, and it's not user fixable. You may need a new belt unit - you can find it for around US$ 80-120, but you may want to have a technician inspect the unit first, since it could arguably be the drum instead, and you don't want to fork around US$ 100 and replace the wrong part.
You can try showing a printer sample at a print shop; by looking at the streaks it is possible to diagnose drum, fuser or belt problems.
Here you find a much more detailed page, for another printer model, but the issues are mainly the same for most color printers:
Mar 25, 2010 | Brother MFC-9440CN Laser Printer
Red prints as Orange
If this is magenta being weak (light) on all the things you print (try doing a test pritn, and a configuration page from the printers own menu system). this will be the dirty laser lens/mirrors problem that is very common with this printer.
Solution is either
Dismantle (it IS quite a lot of work, but fairly straightforward methodical screwdriver work) the printer to remove the laser unit. Take cover off the laser unit and CAREFULLY clean the lenses and mirrors. NOTE take care not to disturb the alignment of any part of the laser optics, and be especially careful with the mirrors as they are surface silvered and V easily scratched.
You can find NEW laser units on a certain internet auction site, and also (genuinely) refurbished exchange printers. Both of these two opttions will obviously save time and effort, but be more expensive.
Jan 20, 2010 | HP LaserJet 2605DTN Color Printer
Okidata C5200N printer: streaky copies on magenta
If the streaks are only from the magenta then your magenta drum is bad. If you recently replaced it, it may still be under warranty.
Jan 19, 2010 | OKI C5200n Laser Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Color Laser Printer prints a streak
Usually a yellow streak would mean the yellow pcu needs to be replaced. You can order pcus from a dealer and put it in yourself.
May 11, 2009 | Ricoh Aficio SP C410DN Laser Printer
Oki C5800 prints magenta streaks
Streaks can be caused by a number of things
The fuser
The toner cartridge
The firmware
The printer needs a cleaning.
The slot in the printer.
Incorrect Media.
Try cleaning the printer, use a lint-free cloth for the ETB, DO NOT touch the belt with your fingers, the oil from fingers will often make things worse.
Always use a lint-free cloth, if you ever encounter dirt inside the printer, dampen the cloth.
Calibrate the printer.
From the printer's control panel menu
Configure Device-> Print Quality-> Calibrate now.
(Press the Checkmark key to advance through menus)
Apr 28, 2008 | Office Equipment & Supplies
313 people viewed this question
