Question about Panasonic DVD-RV31 DVD Player
DVD-RV31 with H02 code
  1. The unit was reset per Panasonic's instructions but still throws the H02 code.
  2. I downloaded the fix software but have no idea how to use it.
  3. Please reply to me at my doernberg@aol.com
  • Anonymous Feb 08, 2008
    Inserting a DVD that played correctly 2 days ago or a new one just now, same error code: H02. Can someone help?
    Thanks
  • Red Wing Feb 17, 2008
    I took the cover off and discovered the motor was not rotating, even when I tried to manually start it. My soIution nwas to junk the unit and buy a new Tosheba unit on close out at CompUSA for $52 and it also plays VHS.
  • 82 Answers
The Spindle motor is defective.
Posted on Feb 16, 2008
Take the cover off give it a good gentle spin counter clockwise with a DVD in it and plugged in. It should start spinning by itself.
Posted on Aug 10, 2008
I have a DVD-RV31. Recently it stopped working and it has H02 on the display. Can I fix this problem?
have you tried a hard reset to get rid of that error?
hard reset is done by keeping the unit plugged off from wall power for one night
Jul 28, 2008 | Panasonic Televison & Video
Error code H02
What is the last thing you did before this problem started?
Jan 13, 2011 | Panasonic DVD-RV31 DVD Player
Panisonic DVD RV-31 Wont read any DVD...shows a "Ho2" code
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VERY CAREFUL NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knackered and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Jan 10, 2009 | Panasonic DVD-RV31 DVD Player
Panasonic DVD RV31 does not read DVDs created by Windows Movie Maker
The only thing that has worked for me is to make a copy of the disk after burning it in Movie maker.
Cordell
Jul 06, 2008 | Panasonic DVD-RV31 DVD Player
DVD player will not read any disc
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VER YCAREFULLY NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knacked and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Jun 17, 2008 | Panasonic DVD-RV31 DVD Player
Panasonic dvd sa-dp1
Jan 19, 2008 | Panasonic DVD-RV31 DVD Player
Plays but pauses every 30 or so sec
Had this problem that degraded into a frozen player within 1 DVD with the error H02. See: http://www.fixya.com/support/t115888-dvd_not_playing_message_say_h02
Mar 07, 2007 | Panasonic DVD-RV31 DVD Player
Panasonic DVD-RV31 DVD Player Logo
638 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
