Question about Ricoh 6513 Copier
Ricoh 6513
I need help with service code sc 541 and sc 422
  • wcspteam Mar 03, 2008
    how can i reset the code
  • Ricoh Expert
  • 1,326 Answers
A sc541 code is with the fixing ass'y did you try to reset it? Did it come right back? Is the fuser warm to the touch? If so it is most likly to be one or both of the termister in the fuser. If it is cold it may be the fuser heatting lamp or thermal fuse
Posted on Feb 10, 2008
What is the sc 422 error on a RICOH AFICIO 6513?
SC422 PCC leak - Timing & Condition -
When the current leak is
detected for 2 seconds,
and the leak detection
started 1 second after the
PCC turned on. This leak
signal is monitored twice a
second. If it is detected
twice in a row, this SC is
displayed.
• PCC unit not properly
installed
• Broken corona wire
• Defective high voltage
supply board
(T1/PCC/BR)
• Defective I/O control
board
• Defective main control
board
Sep 02, 2011 | Ricoh 6513 Copier
Ricoh 6513 Error Code Sc.387 Error Code Sc.457 Error Code Sc.350
1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
Jan 21, 2011 | Ricoh 6513 Copier
Ricoh colar 6513 cod sc 457
SC457 mean Image Transfer Belt Cleaning Unit Position
Error, try to clean the sensor in the transfer belt with a dry cloth.
Jun 21, 2010 | Ricoh 6513 Copier
Ricoh aficio 6513 error code 422
this is a corona leak could be a broken or dirty corona wire
Jan 03, 2010 | Ricoh Office Equipment & Supplies
Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
May 23, 2009 | Ricoh 6513 Copier
Asaad z.essa
Check to see if there is anything stopping the scanner unit from moving freely.  Usually it is cause by a loose screw in the path of the scanner.
Oct 16, 2008 | Ricoh 6513 Copier
Ricoh 6513, service code 551
SC551 is thermistor pressure roller error. Check for paper jams in the fuser. It could need a new thermistor.
Make sure the fuser is secured and properly seated in the copier.
Jun 12, 2008 | Office Equipment & Supplies
Aficio 6513
the proplem solved by adjusting the the home position of the trans fare belt cleaning unit .
May 24, 2008 | Ricoh 6513 Copier
Ricoh 6513 error code PM CAll
Preventive maintenance.....
It's for a clean up, and sometime there's some parts to replace...
Apr 04, 2008 | Ricoh 6513 Copier
Error code
sc 385 is ID sensor vsg adjustment error.Clean the ID sensor.If the developer life is expired replace the same
Sep 05, 2007 | Ricoh 6513 Copier
Ricoh 6513 Copier Logo
234 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
