Question about Sony Ericsson Walkman W810i Cellular Phone
W810i water problem
Mi w810i fel in water and now it wont switch on, i only boughty it a few weeks ago some 1 plzzzzzzzzzzzzzzzzzzzzzzzzz help !!!!
what shall i doooo
  • 2 more comments
  • yasssi Feb 08, 2008
    thanks ill do dat n ill c wat happens errm i put it in the charger in for few seconds and a light red flash apperars and the fone vibrates is dat a goood sighn is da fon not dead yet .. as der might be sum chance of it actually workin !!!
    bye and thank you for the response !!!
    shall i charge it again or will dat damage the fone even more !!!
    bye
  • yasssi Feb 11, 2008
    mi w5810i music player doesnt work properly all the songs keep saying playbackfailed i took out the memory card and inserted it back in , it still says the same thing i restart mi phone and den it starts to play after 3 minutes it stops and again it says playback failed ppllz find a solution to mi problem.
  • smeggas_x Apr 14, 2008
    Every Time i go to my walkman music player on my w810i it says "playback Failed" when i try and play a song Please help i only got this phone yesterday !! the music player was working fine then all of a sudden started saying it HELP i cant listen to none of mny songs :(
  • ben l Dec 20, 2008
    i droped my sony ericson in a big pud le of water and got it out quite quick but the scren was wite i took the batry out and put it back in and it was still wite so i did it a one more time and then it didnt work olz can you help me i dont know what to do i had it off me frend a couple of weakes ago and he would nt give me the money back i have all me numbers saved to the phone plz plz plz plz plz plz plz plz plz plz plz plz plz help
Hi
pls dont turn on the mobil when it is droped in water. it may lead to the internal ciruit damag as the power flow from the battery ill easily pass through the liqued on the internal circuit..
pls remove the battery from the handset and sim also. if u have the hair drier pls blow it on the 10 cm distance with normal speed . so thst water ill vaporise and u can use the mobil again
Note: 1.air blow should be done on the circuit at low speed and 10 cm distance . ok
Posted on Feb 19, 2008
    Novelist:
  • 171 Answers
Remove the battery, your sim card, your memory card, and anything else that can be removed. Take off the back plate, and disassemble the unit as far as you are comfortable you can do without damaging it.
Clean the contacts of the battery and on the phone. Attempt to carefully dry as much as possible with a soft cloth
Allow it to AIR dry for at least 48 hours. Do not use a hair dryer, heat vent, or any other method. It must dry via evaporation in the ambient air.
After that, if the phone still doesn't work, try replacing the battery. I suggest you go to the store and try it in the store before you buy the battery ;)
If all that doesn't work, I'm afraid you phone has been permamently damaged. Water does that to cell phones y'know. You can try and send it to Sony Ericsson, however I believe their warranty has a clause where they say they aren't responsible for water damage.
Posted on Feb 08, 2008
Red light laser doesnt come on anymore
Same thing happened to me today (after 1 day of working). I called the toll free customer service line 1-888-726-6369, told them what happened, they asked for the manufactured month (printed on sticker on back of unit, mine wash March 2012), and will be sending a replacement unit via fedex. Try it!
Oct 21, 2012 | FroliCat BOLT Laser Cat Toy
Mi-am schimbat fotografia de la avatar si acum e doar fond negru, la fel se intampla si cu ceilalti prieteni care isis schimba poza de ceva vreme
1.Deinstaleaza vechiul messenger si ...instaleaza ultima versiune de messenger .
Click aici pentru a descarca .(Yahoo messenger 11)
Va multumesc .
Feb 20, 2011 | Yahoo Messenger
Paloma PTG-74PVN power turns off by itself
turn the water flow off and control off and hold the two arrow buttons together
then use the up arrow to get to e and the down arrow to get to 1 what do you see?
Sep 09, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
W810i water damage?!
havent you got any insurance on it? You usually get 6-12 months insurance incase anything goes wrong you can get a new or get your orginal phone repaired, check on your receipt if you have still got it x jo
Apr 18, 2008 | Sony Ericsson Walkman W810i Cellular Phone
No puedo desbloquear mi celular sono ericsson w810i
take the phone and have it check by a mobile service center tech
Jan 29, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Perdi mi tarjeta y no puedo desbloquear mi celular sony ericcson w810i
Call service provider and have them re-set code for you. >>> Llama la compania de su cellular y hellos le puede alludar con su clave.
Keypad light problem
you should take the phone...to a repair center and have your phone service and also replace the battery, if the battery has a red spot on it the you need to replace it.
Nov 07, 2007 | Sony Ericsson Walkman W810i Cellular Phone
SONY ERICSON W810I
faulty display or software issue
Sep 02, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sansa e250
Switch the usb mode from what ever it is to a different one, and then it should reset it.
Mar 29, 2007 | SanDisk Sansa e250 MP3 Player
Sony Ericsson Walkman W810i Cellular Phone Logo
207 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
