Question about VIA P4X266 PE11-L Motherboard
Upgrade My motherboard is apparently toast. This is what I currently have. Since they no longer make these, what upgrade do you recommend that allows me to use the same components? http://www.eprom.com/home/VIA/pe11l.html
  • coavsfan Feb 11, 2008
    Thank you both for your quick input. It is well appreciated!
  • 983 Answers
You can buy intel 915 , mother board which supports the pentium 4 processor also and it will support other components of ur pc like hard disks, ram , mouse, keyboard , monitor,rom ,writer,smps ,if there is graphics card it will support that also ....
if you want to here my one good suggestion means u can when you really like to upgrade ... you just upgrade your processor also to core 2 duo.... this makes lots of difference to the speed ...
i will explain this core 2 duo technology once to u then it will be clear 4 u...
in core to duo physically there will be only one processors but it will assume as 2 processors while processing so this makes to boost the performance ,speed everything than any other previous processors....
for core 2 duo you must take some intel 965 mother board... there will not be much price difference if you take this processor and it s motherboard also....
Posted on Feb 08, 2008
  • 98 Answers
Used asus p5pe socket 775 ddr ram..ok intel based mother board
How can I buy AM2 cpu board to modernysed motherboard K8 upgrade NF3?
You don't Socket 754 and 939 are dead ends with no upgrades. Most AM2+ CPU'S will work on on current AM3+ motherboards as long as they support DDR3, but anything AM2 or below is no longer supported.
May 31, 2015 | Socket Computers & Internet
Uatx motherboard in mini atx case
Probably however if you upgrade the motherboard you will have to upgrade the CPU, and the memory, possibly the hard drive if the old board is IDE and the new is sata. Also you would have to upgrade the power supply if it's so old it may not have sata power connectors.
Dec 24, 2012 | Compaq Evo Workstation W6000 PC Desktop
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
I want to upgrade L4SMG/651+ RAM can i add 1 gb RAM to it?
That basically depends on how much ram you currently have, that motherboard supports DDR RAM @333 MHz and a maximun of 2GB is allow according the motherboard manual.
Jan 12, 2012 | EliteGroup L4S5MG/651+ Motherboard
Excuseme,I don't speak english, but I need the audio driver for motherboard ASUS P4GE-MX for windows 7 32bit. You can answer me in this address e-mail: jose_a85@hotmail.com thanks
Have you checked with ASUS TechSupport? That is a very old System Board and most likley does not support Windows 7 and Asus most likley has no plans to release any. I recommend buying a newer model of system board, which will require newer CPU, RAM and video card to successfully implement Windows 7 and find drivers more easily.
Check this Asus forum post with similar question:
http://vip.asus.com/forum/view.aspx?id=20081208025209781&board_id=1&model=P4GE-MX&page=1&SLanguage=en-us
Also not sure if you tried running the Windows 7 Upgrade Advisor before you upgraded.
http://www.microsoft.com/Windows/windows-7/get/upgrade-advisor.aspx
it most likely would have advised against installing Windows 7 on the current system and recommended what you would need to upgrade first.
Good Luck!
Feb 17, 2010 | ASUS P4GE-MX Motherboard
Upgrading PC
Backstreet,
Dependending on your budget for your upgrade project you can implement some or all of the following to upgrade your PC.
First thing I would do is to upgrade your Videocard to one of the new PCIe offerings. ATI would be your preffered vendor as your Onboard video is ATI and this will limit any possibilities of driver conflict.
Next I would upgrade the RAM in the system you currently have 1GB which is sufficient for MOST games currently on the market but there are games in developement that can put some extra ram to good use. Your current MAX for this board is 2Gb with a 1Gb module in each DIMM slot.
CPU you can check with Intel and see what other duocores are available that might improve your speed.
Get a pair of SATA WD digital raptor drive (Fastest you can find) and set them up in a RAID array and install your Operating system on it. this is going to allow your computer to access the data at twice the speed as a non RAIDed drive
then I would consider a high end Audio card (My preferred one is the creative Xfi)
Hope this helps,
Good Luck
Dave
Nov 14, 2008 | Computers & Internet
Asrock p4i65g motherboard
Your current motherboard is an mATX form factor. I recommend staying with that form factor for your new motherboard if staying with your current case. When upgrading to the new board you choose don't forget that you may need to upgrade the power supply unit also. You should upgrade to either a socket AM2+ board with dual core amd cpu or socket 775 board with Intel Duo Core2 cpu.
May 02, 2008 | Intel Motherboard
Mp3 not reconizing media player songs?
Throw it away. I spent hours on the thing before I found out about the firmware upgrade, and hours more after that. The upgrade apparently toasted it beause I disconnected after it ran for 15 minutes in "initializing" without any apparent change.
I will never buy anything with CURTIS on it for the rest of my life.
Nov 22, 2007 | Curtis SMP228 MP3 Player
VIA P4X266 PE11-L Motherboard Logo
558 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
