Epson PictureMate 500 InkJet Photo Printer Logo
Posted on Jan 12, 2010
I have replaced the cartridge cleaned the nozzle heads but my photos are a funny fuzzy colour. It is about 18mts old and hasn't been used much Thanks
A
Anonymous
It's a EPSON printer, you have to use it at least twice a month, otherwise the ink on the print heads will dry and clog them. If the printer cleaning process doesn't solve the issue, you'll have to take it to the service center to get the print heads replaced.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on May 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2027
Points
17
I had a similar problem with the photos becoming very grainy and the colours went muddy. I tried a fresh cartridge, realigning and cleaning the heads; nothing improved things. Eventually, in desparation, I tried genuine Epson premium photo paper and the picture quality was perfect. I can only conclude that I had bought a poor quality paper (from Aldi I think).
Stylus dx8450
well it sounds like clogged heads, or Nozzle or an elignment problem
Before anything just run a few runs at head cleaning on nozzle and on head checks first and then run a test print to see if all colours are printing out on test paper first.
I would not like to take through the process of stripping the printer gear assembly down just so the heads can be cleaned but sometimes it can be simply that the cheap cartridges are clogged and will need replacing,
There are built in cleaning methods within most printers one will be a nozzle check and the other is head cleaning under the maintenance section in the properties of the printer,
Sometimes I have had to use up some cartridges just to blast out the dried ink
This is costly but sometimes this has to be done.
another method is as a last resort method please let me reiterate LAST RESORT is injecting or tipping in a few drips of methylated spirits 500ml bottle usually purple a little into the cartidges through the bottom hole which is ok because you have already puntured it to let the ink out when you popped them in there again this is last resort please ware plastic gloves put a cloth out hold cartridge upside down let the little bit soak into the sponge inside the cartridge
this is abit trial and error you need plenty paper and choose a print design thats is going to use or need alot of colours set the printer to max colour like for photo and print a few then run a test to see if you are getting all the colours coming through on the test section if you are problem sorted if you are not nozzle check again head clean again, but do not put anymore meths into cartridge just re run nozzle checks and head checks this will propably run the cartridge out but you will have a back up ready, if after all this you are still not getting getting a good quality picture unfortunatly the heads gone and it will have to be replaced.
hope this helps
1helpful
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
2answers
Colours are printing in yellowish greens and does not look natural. What can I do? Thank you.
Replace the colour cartridge -- you are seeing "mixtures" of only TWO of the THREE "primary" colours.
Printing fuzzy have tried head cleaning etc doesnt help?
Try head alignment using the printers properties ,if the black is fuzzy then try replacing the cartridge do same with colours.
If it doesnt help then you will have to take it to an Epson repair center.
Please rate answer if it helped if not then let us know.
Thanks
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
5helpful
2answers
MAGENTA NOT PRINTING
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
1helpful
Lines thru photos
Try to clean the nozzles with the printer troubleshooter. It will force all the nozzles to print at maximum quality and will clean the clogged nozzles. If the procedure fail, then try again. This happens when you are not using the printer for long periods of time. If cleaning nozzles will not be helpful, then remove the color cartridge from his place and put it with the printing head in warm distilled water for 30 minutes.When the water is coloured by the ink, take the cartridge and touch the printing head with a soft paper towell. If a clear line of colour is printed on the towell, then is OK, put it back in the printer and print a test page. If is not , try again with patience.
3answers
Poor colour
check out the cartridges it must be empty and needs replacement.
thanks.
Epsom R340
print a nozzle check from the maintenance menu
see which colours are missing, run through a few head cleans and print another nozzle check see if there is any improvement
also replace the cartridges of the missing colour they may be dried up. have seen this before where a 3/4 full black cartridge just completely stopped printing
if the problem still persists then get a syringe or an eye dropper and some form of spirit (I have used vodka in the past but clinical alcohol is recommended as not as sticky)
choose change cartridges from the menu then remove the power cord. with the cartridges removed you now have access to the printheads.
using the syringe (or eye dropper) place the nozzle on the spike that goes into the cartrige and inject a small amount of the alcohol leave this to soak for a few mins then mop up the excess with a cloth repeat this a couple of times put the ink back in power up and run another head clean (you can also put afew drops on the spounge that sits under the print head during the head clean
print the nozzle check again you shoudl see most of the nozzles are now working run another head clean if desired now try with a pic
have used this on various epson printers including a stylus 700 R340 & 360
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
