Question about Vicks Ultrasonic V5100 Humidifier
Odor I purchased a Vicks Ultrasonic V5100 N Humidifier last week. I changed the water every day. On the 3rd day, the mist smelled musty, like an old trunk left in a basement. What can I do to make the air smell fresh? Please advise. Thank you.
  • 21 Answers
First, clean or replace the filter. Next, mix a very weak solution (40:1 ratio) of bleach and water to fill the unit. the bleach will kill any bacteria that could be causing the odor, but NOT harm anyone, The filter will take care of any hard water issues. Just don't make the mistake of thinking "If a weak solution is good, a strong one is better". NOT TRUE. Stay with the 40:1 mix unless you like breathing bleach. (Yuk) Note: It may take a couple of days for the odor to go away.
Posted on Feb 08, 2008
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
No green light
Check fuse , unplug remove all screws and look for red cover with fuse in it.
Mar 18, 2014 | Vicks Ultrasonic V5100 Humidifier
There is not mist coming out. What should I do??
The moisture released by this (or any ultrasonic) humidifier should not be visible, so it is very possible that it is working correctly. Try filling the reservoir and marking the water level with a small piece of tape. Then run the humidifier for a few hours, and check the water level again. If the water level is below the edge of the tape, then you know it is releasing moisture into the air, and everything is working fine.
The older style of humidifiers created a mist by spinning a disk that was partly dipped into the water reservoir. They had to be refilled often, and the mist could leave water spots or dust on nearby furniture. The water level should change very slowly in your ultrasonic humidIfier compared to a misting humidifier.
Jan 13, 2011 | Vicks Ultrasonic V5100 Humidifier
The water doesn't seem to be passing through the filter, therefore the bottom reservoir isn't filling up enough to create mist
If water won't pass through the filter, then either the filter has an adjuster that needs to be opened up or the filter needs to be replaced.
Nov 11, 2010 | Vicks Ultrasonic V5100 Humidifier
WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
Aug 15, 2009 | Vicks Cool Mist V3500 Humidifier
Thick Cloud of Steam
I would say that the beauty of steam is that it has to get through the 100 degree temperature to leave the aqueous state - i.e. to move from a liquid to a gas.
The benefit of that is that any organizums in the water should be killed as a result of that process. Its possible that it smelt musty or old stagnant water smells but to be honest there is little change of harm to the little ones.
Best wishes
Aug 08, 2008 | Vicks Ultrasonic V5100 Humidifier
Vicks v5100 need helpa to operate
Go to this link: http://www.amazon.com/Honeywell-V5100N-Ultrasonic-Humidifier/dp/B000056HL5
Scroll down to Product Details.
Download Product Manual [205kb PDF]
You will need Adobe pdf reader to view the pdf file. Do you need Adobe Reader? Download it for free at this link:
http://www.download.com/Adobe-Acrobat-Reader/3000-2378_4-10000062.html
Once the pdf loads in Adobe you can print the manual.
Good luck & best wishes.
please vote...
Mar 06, 2008 | Vicks Ultrasonic V5100 Humidifier
Vicks 5100 humidifer need help filling and operating
You can down load the manual in pdf format from this site:
Scroll down to Product Manual [205kb PDF] & download.
If you do not have Adobe Reader which is used to read the pdf file you can download that from this link for free:
I believe the manual will answer all of your questions..
Good Luck & Best Regards.
please vote...
Sunbeam ultrasonic cool mist humidifer model 700
The Problem is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck.
Feb 17, 2008 | Sunbeam Ultrasonic Humidifier
Humidifer white dust no filter
Try usubg distilled water (or water with less minerals in it).
Feb 07, 2008 | Vicks Ultrasonic V5100 Humidifier
Vicks Ultrasonic V5100 Humidifier Logo
455 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
