Question about Hitachi 57TWX20B 57" Rear Projection Television
Hitachi 57TWX20B powers on ( but no picture or sound)
Worked fine last 7 days. Had a few electrical storms in the past couple days. Had multiple power outages over 1 evening.
Now the set comes on by oush botton on front. the RED light comes on & you can hear the initial Crackle noise that this set always made, but NOTHING comes on, no sound, no menus via the control panel or either remote. the remote will NOT turnthe TV off but it will turnthe TV ON.
I have discounted antenna and reconnected and disconnected power, let it sit a few min. the plugged it in again.
Possible found on blogs could be Convergence is fried, but shouldthat not allow soudn to work? ro at least give some sort of visual projection even it is just color blotches.
Also foudn possible power supply, but would this not allow the red power light to come ont he on-off button.
A PC tech said check the Cooling fan as it could be dirty and drawing so much juice that it is not allow the TV to power up.
ANy help or direction to determine professional reapir would be appreciated.
  • 1 more comment
  • sirromo4u Nov 12, 2008
    I noticed in morning when I woke uppower had been off because of the clock, when I went to turn TV on that same day nothing happened as if the batteries in remote were dead, so I replaced them and I as able to get red light on but no picture. and after looking around back notice many lights are on inside the TV but still no picture at all. Also as if remote still did not work again to turn power on or off, bu you can turn power on and off manually
  • likechristwe Dec 09, 2008
    What was the solution to your tv issue...as i have the same exact issue
  • rafaelbaldom May 11, 2010
    I had a guy come over to put that new fios t.v. connection, he connected the hdmi input plus all the other input wires to the same input connection. Basicly he connected the hdmi , the y p b input, as well as the basic wire inputs all into the vid 1 jacks. Could that have damaged the or overloaded anything.
Hello...Did you ever fix your tv set...and if so...what exactly was the issue as i have the same issue with mine...
likechristwear@gmail.com
Posted on Dec 09, 2008
    President:
  • 4,402 Answers
F you had multiple power outages, i would contact the power company or/and insurance company and it should be covered under that, but sounds like power supply problem if you had power surges
if lighting cause it then it could be anything.
Posted on Feb 08, 2008
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
Philips HDTV does not turn on
i this problem is in pwoer cord u change it try to on it your problem will be sloves
if the poqwer code is ok then chak your tv trnsformer
May 15, 2008 | Quasar VV-1301 13 in. Combo
Wii won't power up
Leave the wii power brick unplugged from the wall socket for 15 min then try to plug it back in. This worked for me.
Jun 11, 2009 | Nintendo Wii Console
Power light blinking continuosly
First off check your lamp or replace it. You can never have too many lamps..........in the last minutes of overtime ! Are you kidding Me! If lamp doesn't work, you will need to find qualified servicer. Try craigslist or tv repair in yellowbook
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 70VS810 70" Rear Projection HDTV
Hitachi 57TWX20B Picture Problem
I just answered this please see my last post
Apr 23, 2008 | Hitachi 57F500 57" Rear Projection...
Hitachi 50vs69a
have power supply normally the voltage regulator gose bad normally start str f668b
Apr 21, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
HITACHI BIGSCREEN TV MDL 57TWX20B APPROX 4-5 YEARS OLD...TV SHUT DOWN WHILE WATCHING AND WON'T POWER BACK UP
This can be one of two problems. 1: convergence output ic's need to be replaced. 2: The problem is in the power supply, most likely a power diode.
Both problems you will need to take it two a repair shop.
Mar 15, 2008 | Hitachi 57TWX20B 57" Rear Projection...
I would check the line coil and horizontal and low voltage regulator transistors.
Jan 21, 2008 | Philips 60PP9202 60" Rear Projection...
look for imperfect contacts on the inside main board.
Jan 21, 2008 | JVC AV-27230 27" TV
Hitachi shows double image and then no picture or sound.
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 07, 2007 | Hitachi 57TWX20B 57" Rear Projection...
Hitachi 57TWX20B 57" Rear Projection Television Logo
148 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
