Question about Indesit 24 in. IDL700 Built-In Dishwasher
Indesit idl 705
Hi our dishwasher starts cycle then drains lights 2 and 3 stay on and the machine will go no further there is no noise and nothing happens when we restart the machine it goes to the same point and stops again can you advice
  • 1 more comment
  • wishful Feb 17, 2008
    already tried that machine emptys ok but still goes no further
  • wishful Mar 04, 2008
    done that no luck same problem but there is no water keaking everything nice and dry
  • Donnajs Jan 12, 2009
    Hi...my IDL 705 Indesit dishwasher has pre-wash & rinse lights flashing after 3 or 5 mins after turning on. It appears to be running smoothly, till the flashing lights. I've cleaned the filter...tried everything, but still no joy, please help!
    Sergeant:
  • 236 Answers
You may be in "flood mode". there may be a leak into the base. or your bottom base hoses may be blocked, best get someone in who is able to strip a d/w base out.
Posted on Feb 16, 2008
  • tony howlett Mar 05, 2008
    the code is water not getting through check the hose is not kinked, the tap is fully on then lastly the transfer supply hose in the base may be blocked. let me know your progress. tone.
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
Indesit idl 705
if the pump is not humming or is humming but not pumping i would replace it.
Nov 27, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Idl 705
i have similar problem machine starts then stops while bleeping the second and third lights then flash nothing more happens have checked water intake which is ok no blockages any more ideas would help thanks
Oct 07, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Sep 19, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Aug 05, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
Aug 24, 2006 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 24 in. IDL700 Built-In Dishwasher Logo
341 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Marvin
Marvin
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
