Question about Bose & Wave& Music System
Cd stuck my cd will not eject. keeps reading disk error
  • Drylightning Jun 17, 2008
    CD stuck in the single CD Bose system. Removed screws and lifted off top then removed CD. Reassembled but now it will not accept a new CD
  • Margaret Beville Jun 28, 2008
    disk error read on two out of the five disk areas.
  • 983 Answers
If you are good at opening the player then just follow this steps...
1.take of the screws
2.remove the cover
3.take off the rubber belt connecting the dc motor
4. now you can take the door out by sliding one white coloured clip
5.now clean the obstacles in the door way and every where
use dry clothes..
6.clean the lens also by using the white petrol or spirit....
then reassemble just put the cd and play...
90% it will work
if you are not good at opening then contact the technician........
Posted on Feb 08, 2008
My bose CD player is not working my cd are stuck I don,t why
Good luck this should do it.
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Feb 08, 2015 | Bose Wave Radio
Cd stuck
Did you try resetting it?
Jun 04, 2008 | Bose & Wave& Music System
CDJ-200 keeps ejecting disk without reading it. Tried to clean with a disk, and with compressed air, but it's still ejecting any CD that I put into it. It was working fine while I was mixing, and then just...
hii there,
Please also let me know if u get any error msg too. If dont get any
error msg. Please try to clean compartment of ur CDJ. But you have to open ur CDJ than clean it. If it does not work again. Then ur
CDJ need adjustment or alignment.
thx,
djajay
Aug 09, 2010 | Pioneer CDJ-200 CD Player
My samsung BD-P2500 Bluray player is stuck at a load message
Hi.
First try disconnecting power cord for five minutes. On restart keep playing eject while the unit is starting up, to eject if there is a disk stuck inside.
Contact Samsung support number, listed on the owners manual. If a firmware update is available they will guide through the update.
If the firmware update does not fix the problem, then the BD player may have a defective or dirty lens.
Using lens cleaner can invalidate warranty, talk to Samsung first.
Dec 14, 2009 | Samsung BD-P2500 Blu-Ray Player
2005 s40 cd(holds 6) player stuck - reads deck error?
that is one of worse nightmare when you have a magazine loader in the systems when the cd get stuck. its common to all cd player some has better luck than others, Only thing I recommend is to take it to your local stereo shop or do it your self taking the unit apart and remove the cd. Keep in mind, when having magazine loader, some of the older unit will not read the new format or burn disk and it will read no disk or error and the cd will get lock. if the unit cant read the cd, majority of the time its does recognize there is a cd in unit. try tuning on and off couple of time and keep pressing eject button. you may have to do it 8-10 times to see if that will release the stuck cd.
Aug 27, 2009 | Car Audio & Video
2004 Jetta CD Player Won't Read CD's
I had the same problem when I first got it.  I realized that the problem was the CD I was putting in.  The CD player will NOT read burned RW CDs.  I hope that helps!  But it will read burned R CDs and ones from the store.
Dec 21, 2008 | 2004 Volkswagen Jetta
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    My disc is not changing and is stuck ( CHM - S620 by Alpine )
    hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
    regards
    Mark
    www.carradiospares.co.uk
    Feb 16, 2008 | Alpine CHM-S620 6-Disc CD Changer
    Cd is stuck
    put the same disk in , play it for a while then eject it properly.
    Nov 13, 2007 | Pioneer AVH-P6500 Car Video Player
    Bose & Wave& Music System Logo
    183 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Invebo
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
