My 13 The picture has running lines and other channels are bleading over
  • 983 Answers
There are several instances for this kind of problems...
1. may be there is a fault in the dish cable.... just tell ur cable operator to check it once...
2. may be the RF cable from the antenna has some problem...
3. may be the CRT tube is out....
4.may be you have not tunned the channel properly...
5. may be there is problem with the s-band and other bands
i suggest you to just take the technician ......
Posted on Feb 08, 2008
What is the proper way to bleed the brakes on this bike with ABS?
Hi,I had a yamaha fj1200 that had abs and when bleading the brakes I just blead the brakes in the normal way,I found that it makes it easyer to blead,open resouveor cap and top up and put a rag around the resouvor to protect any paintwork then get a bungie tie and slowly pump the brake lever slowly as not to creat lots of air bubbles in the system,then rap the bungie around the lever and handle bar to keep the lever pulled in,then go to the back caliper and put the tube in a glass and fill with brake fluid untill it covers the end of the tube,put the other end on the blead nipple a slowly open the nipple just so you can see the fluid coming out,when it stops flowing tighten the blead nipple and do this again untill all the air is out and you have clean fluid coming through,the do the same to the front,job done.
there is a self bleading tube with a valve on the end so that the air dose not go back in the system,there is also a brake bleading system on the market that is a self bleading system where you have tube that connects to the resouvor with its own lid, and a tube that runs from that to a bottle which you put the brake fluid in,and a tube runs from that to a connector like the one that is on a foot pump,that connects to a wheel wich supplies the presure to push the fluid through the system,so with this system all you have to do is open the blead nipple and lock it again when done.
I hope this was some help.
Ive explaned it becouse not every one knows how to do this,so sorry if im telling you how to suck eggs.
Apr 17, 2015 | Ducati Motorcycles
On an orion tv, how can i get channels after 13??
In the menu, find antenna/cable. Locate cable and program from there.
Dec 20, 2014 | Orion1934 19" TV
New tv and no picture past channel 13. What to do?
then maybe it can only find 13 channels from your signal then?
Apr 03, 2011 | Hisense Televison & Video
I JUST BOUGHT A 40"
You have to be on the write input source.
http://www.elementelectronics.com/support_docs/elchw402/elchw402_manual.pdf
Look at page 13 of the pdf and make sure you run a channel scan to find the local channels that are in your area. You might have to hook up an antenna to get reception depending on your location.
Mar 05, 2011 | Element Electronics Televison & Video
Weather bleads Over on 21 LTD WX CLASSIC(*HELP*)
sounds like your wx receiver is being activated by a bad switch replace the switch to disable the wx when you dont want it to come thru
Jun 10, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
I am trying to get channels above 13. I do not
Try bringing up the menu by holding both volume buttons down at the same time (or use menu button on remote if you have it). Go into CH SET using the channel and volume buttons on the front of set (or use the SET + and - and the ENTER buttons on remote). Go to the TV CATV line and move the arrow to CATV. Let menu time out. This will put tv into cable mode. Hope this helps.
Mar 12, 2009 | Durabrand DU1901 TV
Tuning or programming?
no tv signal at this outlet for cable. make sure center conductor of cable is coming through at both ends-may have been pulled away from wall outlet.
Apr 29, 2008 | JVC C-13811WT 13" TV
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Picture quality
Which channels? Tuners are divided into bandwidths-----
2-6 is V low, 7-13 is V high and so on.If say, 2-6 acts up, but
7 thru 13 never does,then the tuner is bad.
This solution assumes that video inputs were ok......T.
Oct 24, 2007 | Toshiba 53AX61 53" Rear Projection...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
