Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
36" Sony Trinitron blinking red 4 times-PLEASE HELP QUICK!
My husband's precious TV has died! Moved a few months ago, since then occasionally TV would cut off and come back on in seconds (sometimes after hitting it). Two days ago I came in after being gone for a few days and it would not turn on at all. I could hear the "thung" sound like it was, a small flash of light at the bottom right of the screen but no picture at all. After a few seconds the smaller "thung" of the TV shutting off and then the red standby light is constantly flashing 4 times. We've already tried the hard reset and the whack/smack test (with vigor). Any other suggestions? I bought this used for about $300 over a year ago and I don't want to spend a ton to fix it. Should I scrap it or is it worth the repair? Thanks for any and all input/advice!
I have a 50" Grand Wega rear projection TV and the screen flicks sometime every few minutes and sometimes every few seconds. this is something new, and I am not sure what is causing it, very annoying problem, you would be watching a program and all of sudden the screen disappear for few seconds, and also the sounds would disappear with it. anyone have an idea of what is going on here? would highly appreciate an informative response.Thanks
    Guru:
  • 1,894 Answers
Hello sir
Posted on Feb 08, 2008
  • dewan nafees ahmed Feb 08, 2008
    for first question
    G1 board has to be replaced, could it be the F Board also.
    but replacing them will cost you for more than a 200$ to 250$ including the techs charge.
    so i dont recommend the repair at this stage.
    for second problem
    this is the signal board going bad. the problem is there is capictors
    going bad on board. as they get old(or inferior quality) they leak onto the pcb board. this
    board is no longer made. tring to have it repair is not a good thing.
    it will work for a time but not long.
    so better replace the board itself to be peacefull for a period of time.
    good luck.
    dont forget to rate solution.
    thank you mam..
I have a sony wega trinitron, when the tv is turned on, (no visual, or sound) the red stand by light blinks 7 times, and you hear the tv click off? Please help
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jun 06, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony WEGA KD-34-XBR960
Push display - 5 - vol + or - then power. Clear CH setup if there and if the right numbers are not zero the push 8 then enter, that will clear the numbers, like reset. IF unit no workie the start up that way and any zero with numbers are what the units problems are.
BC
Oct 13, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA Won't Turn On
The key here is the count of the blinks. I'm assuming that the model number is KV-36FS120. Please post the blink count. It should be a count-pause-count...
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Feb 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
PLEASE HELP QUICK! 36" Sony blinking 4 red times
probably this is the small mailfunction,probably some contacts,but you probably not a qualified to do this repair ,so please call a service man
Feb 07, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sounds like a typical high-voltage failure. Could easily cost another $300 to have it fixed. If it is less than about 6 years old I'd say it was worth fixing. If you want to DIY, then pull all the electronics out (label all the connections) and send it all to either Module Exchange at 972-298-1212 or PTS Electronics 800-844-7871
Feb 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv stopped working
HV problem. I'm sorry but there is a time for the TV dudes to come see everyone and this is your turn...accordianman
Oct 10, 2007 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
