Question about Tomtom GO 700 GPS Receiver
Tomtom my tomtom 710 wont come on. The green light comes on when charging but when I press the the start button on top of the tomtom nothing happens
  • 1 more comment
  • Johhhn Feb 09, 2008
    Exactly the same problem! Tomtom710
    Also the computer does not "see" the device in the docking mode
  • Anonymous Feb 14, 2008
    green light on when pressed, nobody home. tried reset, no solution.
  • Anonymous Feb 19, 2008
    The exact same problem is happening to mine.Ain't managed to get inside it yet as hex screws v.small but feel its condemned to the bin.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 171 Answers
I have worked on several tomtom 710's and 910's with this problem. About 95% of the time the negative pin losses connection and needs to be re-soldered. If you have a OHM meter turn it on to check continuity. turn your unit upside down with the screen facing away from you. The docking port should be facing toward you. Next take the red (+) probe and touch the solder joint on the far left (right below the gold contact pin) then take the negative (-) probe and touch it to the go;d contact pin. If you don't get continuity you have discovered your problem. To repair you will need a number 6 torx driver and remove the 4 torx screws under the ends of the rubber strip (you don't have to remove the strip just lift the ends up). Remove the face plate. There is an indention on the case on the bottom so you can get a finger nail under it. Pry up carefully till you get it off. Next the back housing should come off ( you have already removed the 4 screws). After removing the back housing you will see 2 torx screws on the top remove them (this is the sat antenna). You don't have to remove this piece. Next remove the 4 screws holding down the motherboard remove them. Next gently pry the motherboard up but be careful, you have to remove the speaker and battery cables before removing it completely. Also be careful of the wire spring on one side, this is your phone antenna.
After removing the motherboard check again for continuity. The gold pin on the far left (with the contact pins closest to you) is the negative side. The contact pin to the far right is the positive pin. Normally all you have to do now is use a small soldering iron and and re-solder the soldering joint just below the contact pin.
Hope this helps
Posted on May 29, 2009
My tomtom charges the green light comes on I press the on button but nothing happens
I have managed to fix my TomTom one.
The problem was two fold. First the diode D8 was blown and also the power supply chip was blown.
It is a tricky job, using surface mounted components so should not be attempted by a novice but I managed it.
I have a full set of photos etc if anyone cares to try it. I figured - NOTHING to loose!! so what the heck and just went for it. Taking it apart was fun! The surface mounted IC was easy to obtain and the total cost was about £10 plus 4 hours panic labour. If anyone wants the info just let me know and I will send the photos - but no promises - it worked for me.
I figured out this ongoing problem. I purchased my TomTom One second edition 1/20/07 for $395. I was 30 days past my warranty and had the problem of unit not turning on. Green light came on when charged.
I opened my unit up and found the sw2 micro switch broken. If you press too hard on the on/off button, this will eventually happen.
I couldn't find a replacement switch so I wired my own switch and it works now.
Oct 26, 2010 | Tomtom ONE XL GPS
TomTom Go 910 comes on, then goes off
Sounds like a dying battery. There is not enough charge being maintained in the battery to complete the loading of the data. ChaNGE THE BATTERY
Jul 20, 2009 | Tomtom GO 910 GPS Receiver
Hi, Tom Tom 710 has not come on for weeks.
it doesnt get better by itself. Despite having a green light doesnt mean it is charged. try changing the battery
Jul 05, 2009 | Tomtom GO 700 GPS Receiver
My tom tom 710 is dead the green light is on but nothing on it!
Change the motherboard, green light on and nothing happening is quite common, you can find motherboards on ebay for £22 +p&p.
Its quite easy to do and worth while as the 710 and 910 are still very good units.
Dec 27, 2008 | Tomtom GO 700 GPS Receiver
Tomtom not switching on
I had this problem. had it plugged in charging and then pressed the the reset and the power button at the same time for about 30-50 seconds and then after that pressed the power button and so far so good
Apr 02, 2008 | Tomtom GO 700 GPS Receiver
Tom Tom Go 710
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
Jan 13, 2008 | Tomtom GO 300 GPS Receiver
Tom tom 910
Try pressing the reset button, check your documentation for the location...but it's at the connection interface.
May 21, 2007 | Tomtom Go 910 (Europe, USA and Canada...
Tomtom GO 700 GPS Receiver Logo
346 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
