FixYa.com
Tags:
Panasonic WV-CM1020 Television
Unit is dead....
posted by TNExposure on Feb 08, 2008
This unit suddenly stopped working. It will do nothing. I have checked the fuse and the switch and both are good. I have now started checking individual components with a meter. However if someone has a quick tip, something to check or a schematic, it would be greatly appreciated.
Comment by TNExposure, posted on Feb 16, 2008
Thanks for the info. A large ceramic wire wound resistor on the AC side was open / not showing any resistance. I replaced the part and that took care of the problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 08, 2008
Helpful (85)
sharcnet
Rank:Guru Guru
Rating: 91%, 301 votes
The power supply is the first place to start.
Is there a transformer? Check to see that there is AC on the primary & secondary of the transformer.
If no AC on the secondary, then the transformer is bad. If AC ok on the secondary, then look for a bad rectifier diode/module and/or regulator module. There might also be fuses on the DC side of the power supply.
If the unit is completely dead, it's most likely a power supply issue.
Please let me know if I can be of further assistance to you.
- Jim
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Portable Televisions problems?
colour television problem
i got some problem in samsung... Answer This...
philips tv model 14gx8310/75r...
I have lost the remote and cant... Answer This...
what is the weight?
RCA television model f32650 ... Answer This...
trutech problem
Have a tru-tech TV 21"(not... Answer This...
No picture, but I get sound
I can get sound, but the screen... Answer This...
Repair Service
Find Portable TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
