Question about Whirlpool GGW9200L Gas Dryer
The dryer runs by does not ignite.
The gas gets to the gas valve and the first coil clicks but the second coil never clicks. I have replaced and tested new and old coils they are fine. I have replaced all fuses, sensors and igniter. I just can't get gas to the igniter. It worked fine, then intermittent, and now not at all. Any help? My next thought is the electronic control assembly.
  • 3 more comments
  • ndn49r Feb 18, 2008
    everything runs on the dryer. I have checked and rechecked the harness but can't find anything wrong. The harness has no nicks or rubs that would short it out. The only issue is the second solenoid on the gas valve does not click releasing the gas to ignite. The drum turns and the wires are connected tightly.
    Thanks
  • ndn49r Feb 19, 2008
    Checked both sensors and replaced even though they checked fine.
    I even replaced the 'board' because of previous issues about a year ago that resolved itself somehow. I still can't get the second solenoid to release the gas.
  • ndn49r Feb 20, 2008
    The first and second solenoid on the gas valve connect about 8" away from a Y harness. The wire harness then runs back to the board. The the Y harness has continuity to the both solenoids. I have not checked the main harness from the board to the connection at the Y. I will do so. The harness has no nicks or blemishes so I never checked it for continuity based on appearance.
  • mdewey Feb 17, 2009
    GGW9200L will start but the gas burner will not lite
  • ndn49r Sep 02, 2009
    I give up on this issue but now I am back at it.
    Can you tell me what setting to put on the voltage meter to check for voltage across the second solenoid?
  • 958 Answers
Kindly check all wirings to and from the igniter assembly. does the drum turns?
Posted on Feb 16, 2008
  • 1 more comment
  • francis rivero Feb 19, 2008
    kandly check all safety sensors, overtemperature sensors, they should have continuity. they are located on the air duct, or supply duct sometimes it is only one , sometimes two.
  • francis rivero Feb 20, 2008
    you can trace the wires that goes to that second solenoid and find out where it goes then you can trace if it is being cut off by some thing or the board itself is not giving the power to turn it on.
  • francis rivero Feb 21, 2008
    after you checked with continuity, can you check for voltage readings accross the terminals of the second solenoid without jeopardizing your safety? ( be carefull )
Dryer flame keeps going out
replace the gas valve coils on the top of the gas valve,they get weak and can no longer hold the valve open,then they cool and repeat the same condition,they may appear warm after shutting off,remove 2 screws off bracket holding them on and unplug each coils harness and replace coils,there are plastic pins for getting them in the right position,so its hard to reverse them
Jul 23, 2012 | Amana NGD7200TW Gas Dryer
Sg7800 maytag dryer stopped giving heat
Sounds like burner not igniting. On front of dryer in the lower right there should be a gas valve/burner access panel. Usually you just have to pry out at bottom of panel & swing out and up to remove. This gives you access to valve coils and igniter. With panel removed set timer for heated dry and start dryer, observing first the igniter which should glow bright orange-red, then after a couple seconds you should hear a "Click" which is gas valve opening and a blue flame ignites for heat. If no glow is seen after a few seconds or at least a minute, igniter is bad, if it does glow and no click is heard from the gas valve, the coils (electro magnets) on the valve are bad, or the "Flame present" sensor is bad. Chances are it's either the coils or igniter.Try this on all heat settings, if you get heat at only one setting it might be in timer contacts, but not common. Again you can repair/replace both the igniter (usually just plugs into a receptical) and the coils (2 donut looking objects on the gas valve, replace both.) Access door may be on back if not on front, but normally their on lower right of front.
Feb 13, 2011 | Dryers
My dryer is not heating It is a gas dryer and has done this before. I think lint has gotten built up inside and there is a sensor that turns off the heating element. How do I fix that without calling a...
Hello there:
Here is some helpful advice for you to check out first ok
Hope that al of this is very helpful for you
Best regards Richard
Most likely your gas valve has a defective solenoid. You can verify this by visually looking at the glow coils operation.
The first click you hear will ignite the glow coil. If the glow coil does glow a very bright yellow white color, that solenoid is working. If the glow coil fails to light, replace that part only. <Use caution-glow coils are not cheap and break easily.>
If the coil glows but you do not hear the second click, which opens the second gas valve to allow the gas to exit to the burner, you will need to remove the gas valve assembly and replace both solenoids.
The solenoids are located on the top of the gas valve and are black plastic coated spool looking items. They are held in place by a retaining plate.
Carefully, remove and replace them with the new ones. <They only fit on the steel rod one way.> Replace the gas valve assembly, attach the quick disconnect wire clips and soap test the gasline nut you unconnected.
If the soap test proves there isn't any gas leaks, fire up the dryer and your done.
Glow coil's cost about $50.00.
Pair of solenoids slightly less.
Dec 15, 2009 | LG Dryers
Kenmore gas dryer is not getting hot
But the clothes drum is turning? Running? If you have a electric dryer you need to replace the heat elements. If gas you need to replace the igniter coil.
Oct 19, 2009 | Dryers
The dryer runs, but there is no heat. Gas is
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Aug 20, 2009 | Kenmore 700 6972 Dryer
Dryer's flame cycles but will not burn
Check the following to address this issue..
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 01, 2009 | Dryers
Flame goes out in 15 seconds
check these: Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
May 17, 2009 | Dryers
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Whirlpool GGW9200L Gas Dryer Logo
154 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
