Question about Brother MFC-7820N Laser Printer
I get a load paper message when paper is loaded
I have faxes in memory and it keeps telling me to load paper and push start. I have loaded and unloaded the paper several times but the machine does not recognize it. This machine is less than 6 months old.
  • 11 Answers
Probaply some paper or obstackles stuck at PE (paper empty sensor) and that could be hard to fix it cuz you may need to pull apart the printer. However, if it is 6 monthsold, warranty covers this problem.
Posted on Feb 17, 2008
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
Our fax machine is sending faxes fine, but will not print in coming faxes. It keeps asking for paper (which is in the fax machine), then it sounds like it's working, then stops. We turned it off to see...
The paper isn't properly loaded. remove the paper then there should be a lever near the paper loading section that you push or pull to let the paper enter the feeding area. put in paper and return the lever to the proper position. check your owners manual. to get a manual try www.sharpusa.com .
Dec 16, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Can't receive a fax
The machine might not sensing the paper that is being loaded, this might be due to the paper actuator is not functioning properly.please check the actuator if it is being actuated by the paper and it is returning once the paper is removed. if not please a technical person to rectify it.
Feb 21, 2009 | Office Equipment & Supplies
PAPER TRAY NOT RELEASING
After puting paper in the tray you should press the start button. GOOD LUCK.
Nov 20, 2008 | Samsung SF-560 Plain Paper Laser Fax
CANON FAX MODEL L220
Hi Greg.
Press the red STOP button.After loading paper.
Nov 07, 2008 | Office Equipment & Supplies
Says load paper recv'd in memory
I had same problem. I put in a big bunch of paper and then took out about half of it and it suddenly worked. Also try opening the lid and then closing.
Jun 17, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Paper feed
Is your paper right in slot with grey flap over top of paper feeding into slot.
Apr 08, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Keep Adding Toner to Panasonic KX-FL511
kindly follow this instruction
but doing this will erase all the message in the memory
press menu #9000*550 start
unplug the unit once heard the beep
after 10 seconds, plug it again
Jan 28, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Nov 17, 2007 | Canon FAXPHONE L80 Laser
Sending and Copying Problem
THE SCANNER NEEDS CLEANING HAPPY FAXING OMNIPRESENT
Mar 27, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother MFC-7820N Laser Printer Logo
154 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
