Question about LG LRSC26920TT Side by Side Refrigerator
Ice box the ice in the ice box keeps freezing together,
    Champion:
  • 210 Answers
In the LG side by sides they have developed a new ice cup tray. The tray has a little wall so that the water stays in the tray and doesn't go onto all of the ice causes it to stick together.
part number is 3390JA1150A
Sgt 48
Posted on Jun 01, 2008
  • 92 Answers
Tough one is there any water droplets on the underside of icemaker tray could be you need an updated ice cube tray if water is splashing during the fill it may be a bad bi-metal causing the defrost cycle to over heat the freezer that will usually cause frost build up on the food
Posted on Feb 10, 2008
  • 298 Answers
The Ice Tray can be located at http://www.andrewselectronics.com/
Direct Link:
LG Replacement Ice Tray
Posted on Jul 03, 2008
3 Suggested Answers
  • 351 Answers
SOURCE: Ice maker freexes ice together
maybe too much water going in to the ice maker
Posted on Jun 30, 2009
  • 40 Answers
SOURCE: Ice maker freeze ice together
If mechanical or electronic then it has to be replaced with a modified one no way to adjust.
Posted on Jul 01, 2009
GE side by side refrigerator-freezer daily makes loud grrrrrnng noise. Sporadic. Comes from area just above ice maker. Makes no difference if I turn ice maker off. Any ideas what is causing this?
Many ice maker sporadically turn to keep ice from freezing together and becoming a solid block of ice. This would occur even if the ice maker is turned off in order to keep the ice already made from freezing. It is generally short and not that loud. I'm surprised you find it disturbing.
Jun 27, 2016 | GE Refrigerators
Why would my ice maker start freezing all my ice cubes together?
ice maker made cubes, but you shouldn't put in freezer any warm staff, its melt ice for while after freezing them together
Jul 29, 2014 | Jenn-Air Jenn Air Refrigerator Replacement...
Its a 450 mah hoshizaki, it keeps jumping from freeze cycle to harvest cycle without giving it enough time to make a load of ice
usually, if it does not stay in the freeze cycle long enough to make ice or it just makes slivers of ice, it is loosing water. during the freeze cycle, look to see if water is draining down the drain from the machine. If not, I would look at the float position. it should be almost completely in the lower, down position. give that a shot.
May 31, 2014 | Hoshizaki Cubelet Ice MakerDispenser Water...
Ice keeps getting stuck in ice maker # fsc23r505b2
Most icemakers have a low voltage defrosting element wrapped around the ice shute to prevent the ice from freezing and jamming up. Carefully have a look for any disconnected wires or damage to the heating element. If the ice is getting "glued" together in the ice box itself, its likely that the water tray is overfilling and causing water to run down into the ice box. When it freezes, it freezes all the ice blocks together. In this case, you may need a new ice maker tray or ice maker water valve.
Oct 20, 2013 | Frigidaire Refrigerators
My ice dispenser won't work, it just hums help
make sure the metal bar in the box that holds the ice is down.....if thats not it take the box out and clean all the ice out with warm water...sometimes the ice will freeze together in the bottom
Nov 04, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Ice maker makes ice then water dripps and freezes
water valve not working properly needs to be replaced ... located on bottom back nof fridg
Aug 11, 2009 | Kenmore 21.9 cu. ft. Side-By-Side...
Ice buildup in freezer...
try using a hairdryer directly on the switch, you know the two ducts that freeze up behind the back panel needs a duct heater or its gonna keep freezing up!!!!
Jul 18, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice maker makes icecycles under where the ice is made!
Try turning up the temperature control .
Mar 24, 2009 | Refrigerators
LG LRSC26920TT Side by Side Refrigerator Logo
237 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
