One Touch 4 Maxstor 750 external hard drive installing on a macbook pro
I need help with installing an external hard drivce on to my new mac book pro - the external hard drive is a maxstore onetouch4 750 - it installs okay on a windows xp computer but my macbook pro doesnt recognise it.
Please help
  • 1 more comment
  • Anonymous Sep 28, 2008
    WHEN I TRY TO MOVE FILES TO THE HARDDRIVE IT TELLS ME ITS NOT MODIFIED
  • Clyde Van Graan Oct 14, 2008
    How do I change the setting from NTFS to FAT 32
  • melissab127 Dec 13, 2008
    I am trying to use my Maxtor Basic 500Gb hard drive on both a PC and a mac but do not know how to change it to FAT32 s both machines can read it. Can you help?
  • 39 Answers
If you have a hard-drive that is formatted as NTFS which stands for (New Technology File Ssytem), Mac OS X can only read the partition. It cannot write to it.
The trick is to use your drive manfacturer's disk-formatting software which will allow you to format your drive as one large partition. Formatting your drive as one large FAT 32 partition is the easiest way to make a drive so it can be used with both PC's and Mac's.
Another option is to use a third part utility so that you can read a MAC formated harddrive's from your PC. Here is one option: http://www.macdrive.com/.
Good luck.
SeekPCRepair
Posted on Feb 09, 2008
Macbook Pro replace Harddrive
Take off the bottom. Remove the screws from the hard drive caddy. Remove the cable from the hard drive. Reverse to install the new drive. Be very careful with the cable as they are very fragile.
Mar 14, 2013 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Apr 23, 2011 | Apple Computers & Internet
I just bought a mac book pro 13.i would like to know how can i create a recovery disk for my laptop
Can i ask why you need to make one?
Its best to clean your drive first, then you have to make 2 disk images, mounted on your desktop.
Jun 30, 2010 | Apple MacBook Pro Notebook
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard Drive not mounting
Check the jumper on each hard-drive.
My guess is that the WD drive has the jumper in the "correct" position, for mounting inside an external case, while the other drives have their jumper set to an "incorrect" position.
Set the jumper to MA(ster), not to SL(ave), nor to C(able)S(elect).
Sep 08, 2009 | Macally 1 Bay PHR-250CC (0701107485355)...
Maxtor manager software shows no drives
First and foremost if you're getting power but not seeing the drive you likely have either a drive or enclosure circuitry failure.
If you have no power lights try a new power adapter.
If the drive has failed and you want the data back you will need a Data Recovery Pro to asist you, if the enclosure has failed it will be much simpler.
Step one take the drive enclosure to a PC shop(no offence to Mac techs but they stink at salvage efforts, must be too many years of promising nothing ever fails ;)). When you get there ask them to remove the hard drive from your Maxtor enclosure and pop it into a generic enclosure(looks cheap but the internals are identical in most cases). Then ask them to test the drive to see if it shows up, depending on how you formatted it they may need MacDisk to make it visable.
If it works, buy the enclosure and head home, you're done. Plug it into your Mac and go on with your day, no harm no foul.
If this fails to see the drive, then the Hard Drive itself is likely at fault, in this case reply to me with your Country, State and City and I will refer you to the closest Data Recovery Facuility with Mac capabilities to have your data retrieved,
Of course if the only data on it is still accesible on the computer and it's a dead drive, just buy a new external, head home and rerun the backups manually as in this case it's cheaper to chuck and replace the external than have it recovered.
Hope this helps FixYa,
Chris
Aug 05, 2009 | Seagate Maxtor 750GB One Touch 4 Plus...
VOX 500gb won't connect to PC.
Go to Utilities and format the drive for Mac.
May 19, 2017 | RPM Vox 750GB 3.5in USB 2.0 & eSATA...
External hard drive won't work with Mac
It needs to be formatted for macs.
I had this problem and with mine as well. (VOX is a horrible company)
One of these two processes should work but I forgot which I did.
Go to spotlight and search for disk utility. If the drive shows up on the left you can click on it then. Click the erase tab. select mac formatting and then click erase.
If it does not show up when you do this you will need to do the same process on a PC.
Mar 26, 2009 | RPM Vox 750GB 3.5in USB 2.0 & eSATA...
WD 500GB external hard drive won't load on new macbook
Dear Sir,kindly note this problem usually caused by a firmware damage,so you need find a dr company to use tool to repair the firmware,you can contact with me :honglake@gmail.com
Mar 19, 2009 | Western Digital 500GB My Book Pro-External...
Computers & Internet Logo
569 people viewed this question
David Payne
David Payne
