Anybody know someone who has dunhill lighter parts ?
You can reach me at [email protected]
Thank you.
SOURCE: Dunhill cigarette lighter spare parts needed
Hi, Dan, I have 2 Dunhill ighters that work but they leak butane. Making them unfit for use. I would like to have them repaired/rebuilt. I believe they are 1960-70's vintage so, the lack of parts will definately be an issue here. Please advise. Thanks Glenn [email protected]
SOURCE: refilling a dunhill lighter
All rechargeable lighters have a refilling nozzle (usually at the bottom of lighter).
All the good quality gas refill cans have the nozzle adapters inside sovering cup.
Brake off the nozzle adapters off the cup and try to fit them onto lighters refilling nozzle.
When found the best fit adapter, put it onto gas refill cans nozzle and holding the lighter and can upside down connect all nozzles together and push together.
As these nozzles are made for mass production lighters, tey do not fit perfect and some gas leak will occure.
Anyway- few seconds will be enough to refill any lighter.
In case if your lighter do not refill by explained action, the refill nozzle in your lighter is damaged or faulty.
Hope it does help.
Do not forget to rate, please.
SOURCE: how to fit a flint in a vintage dunhill
On the underside opposite the flint there should a screw head.
Remove this screw (take care, there will be a spring inside!) .
Turn it over and the remains of the old flint should drop out.
Insert new flint and re-assemble.
Testimonial: "What a relief- someone knew the answer!!"
SOURCE: I've inherited a dunhill lighter and want to
I suggest that you go to the Dunhill web site (www.dunhill.com) and go to the bottom of the page where you will see a menu in small type.
Click on "contact" and you can choose the nearest center. They should be able to answer your question.
Anybody knows someone who has dunhill lighter parts ? All I need is a screw for a dunhill aladdin's lamp lighter.
Thank you.
