Question about Toshiba 36A61 36" TV
Tv trouble blackbackgrond with white line through the middle
  • dylandog Feb 08, 2008
    does anyone know how toget into computer,the password somehow isn't what i thought it was.dont care about losing info.i've tried safe mode.ihave tried just about every thing
  • 2,130 Answers
Sorry, I can't help you with the computer password issue but I can help you with the TV.
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Good Luck!
- Jim
Posted on Feb 08, 2008
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
May 11, 2010 | Televison & Video
Two white gost lines in the middle on the middle of the page ( one two millimeters wide) , the other 2cm away and one ml wide with shadows There are several other with similar distance from eacjh other but...
Something is wrong with your printer -- part of the drum is *NOT* holding the magnetic-charge that the laser should be creating. So, none of the ink "sticks" to the paper, resulting in a WHITE strip.
Take the printer to a qualified technician, for proper trouble-shooting & repair.
Apr 05, 2010 | Konica Minolta magicolor 2400 Laser...
The tv has a 3" white verticle white line down the middle
Sounds like your LCD panel is failinf and will need to be replaced it is going to be costly around 1500
Nov 29, 2009 | Samsung LN46A750 45.9 in. HD-Ready LCD TV
RCA 27 in has white horizontal line going through the middle
this symptons is caused by a breakdown in the vertical deflection circuit. hence, the trouble may be in the vertical oscillator, amplifier or output circuit. in most modern tv the vertical ic is usually composed of these said circuit inside. the ic have many pins, standing on a heat sink and smaller in size. try to check also the capacitors surrounding it. sometimes leaky capacitor may cause this problem. good luck!
Aug 16, 2009 | RCA TruFlat 27F520T 27" TV
Problem with tv
The problem is sometimes caused by the vertical output integrated circuit (IC) failing, but usually it's bad solder connections. If you or someone you know is comfortable with electronic soldering, a few minutes spent resoldering the IC pins to the circuit board will often solve the problem. Failure of these connections is common because the IC gets quite hot (and it's mounted on a metal heat sink). The heating and cooling cycles cause the solder joints on the circuit board to crack. You can usually see the trouble with light and a magnifying glass; gray grainy joints instead of shiny connections, and often visible ring cracks around the pins.
Mar 31, 2009 | Konka K1938U 19" TV
Tv trouble
MOST BE A VERTICAL PROBLEM if the line cross the screen from left to rigth,,, and if the line cross the screen from top to buttom then is an horizontal circuit problem any way you need a tech how ever if you know about tv repair and have somes skill in the campus try resoldering the vertical output IC....good luck and rate me
Jan 20, 2008 | Emerson EWF2703 27" TV
TV Screen
im pretty sure you cant fix that you probably need to buy a new one.. i know that because my somputer has a white line that runs right down that middle, not all the time but sometimes. my father looked into fixing it and he found out that you have to buy a brand new screen or tower or something like that.
Dec 31, 2007 | JVC AV-32020 32" TV
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
POP and noothiing
yes it can still be fixed! the pop sound you've heard maybe came from a blown capacitor in the vertical deflection circuits. this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 10, 2007 | RCA E13309 13-Inch Diagonal XL-100 Color...
Toshiba 36A61 36" TV Logo
103 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
