Question about Sharp AR-C270 Color Copier
Sharp AR-C270 Copier Error code F11
Copier was donated and is getting error code F11. In calling local copier company I am told that there is no such error code, yet the copier says differently. Is there some way to reboot it to clear this code?
    President:
  • 2,072 Answers
Have you tried unplugging the finisher to see if that eliminated the code? Or gives you a different F code?
Posted on Feb 12, 2008
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
Jun 14, 2016 | Sharp Used AR-M207 Copier Printer Scanner
Sharp mx -2700n error code l4-11
3838e66.gif look at the picture if not understand replay me.
Oct 28, 2010 | Sharp AR-C270 Color Copier
Error code u0-80
Hello sir; U0-80 means PCU board have problem, send it store for repair.
Aug 11, 2009 | Sharp AR-C270 Color Copier
Sharp ar-c330 with an error code of H4-01. Any
The fuser temperature is low.
Use sim. 5-02 to check blinking of the heater lamp.
if it blinks normally check the thermistor and the harness.
If it not lighted check the heater lamp and thermostat if its defective replace the heater lamp or the thermostat.
Jun 10, 2009 | Sharp AR-C270 Color Copier
Sharp arc 270 error code l4-04
Possible bind in one or more of the developer units. Replace as needed. Sec. 11 Page 11-61 it talks about Paper Feed Drive Motor, it is the same motor as the Black Developer Drive Motor.
For L4-04 swap those two motors around to troubleshoot bad motor
Feb 03, 2009 | Sharp AR-C270 Color Copier
Sharp AR C-330 Error Code E 710
E7-10 refers to black shading correction.
sometimes caused by a poor conection between the icu and the ccd. check ribben cables.
Nov 28, 2008 | Sharp AR-C270 Color Copier
Sharp Copier AR-C270 Code Problem
jam in the fuser unit, try simulation 14
and/ or possible bad sensor switch actuating as tho paper is stuck in the fuser. check that exit switch is not stuck open or bad. if jam elsewhere , fuser will not allow operation untill jam somwhere is removed.
Jan 30, 2008 | Sharp AR-160 Copier
NO IP ADDRESS FOR THE AR-C270 sharp copier!!!!?
Custom settings, List print, Print test page, NIC Page.
Dec 15, 2006 | Sharp AR-C270 Color Copier
Sharp AR-C270 Color Copier Logo
135 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
