Question about Maytag MER6772 Gemini Electric Kitchen Range
Small oven both elements come of when bakes cycle is used. have alot of burnt bake goods when trying to bake
  • 770 Answers
Here is the repair manual for your model
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Posted on Feb 17, 2008
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Oven won't heat
quite possibly the element burnt out .
Sep 22, 2017 | Dacor MCS230SS Millennia Electric Double...
The lower element burned in my oven. I replaced the element, but the oven will not work.
unplug range ..remove the back cover plate check all wires all connections ..their must be a burnt /broken /dissconnected wire ..check where the wires connect to the bake an broil element ..and the bake broil switch..if all looks good .then the bake broil switch burnt out when element blew out..plus is the breaker tripped in the box ..it prob. tripped when the element blew out..let me know..good luck
Aug 28, 2010 | Frigidaire FEF366 Electric Kitchen Range
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
Hi ,I have model jgs8850ads,it takes along time to preheat,about 40 min. what could this be? please respond.
is this a duel fuel with an electric oven..... the bake is the bottom and the broil is the top both cycle on and off to preheat the oven.... if ur lower bake element is burnt out then u woould expereicnce the problem u stated..... if u have a gas oven then ur ignitor or glow bar is probably burnt out....... either way it sounds like your bake element or bake ignitor has failed
Jan 31, 2010 | Jenn-Air JGS8850ADS Gas Kitchen Range
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Maytag MER6772 Gemini Electric Kitchen Range Logo
78 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
