Question about RCA DRC8335
Blue Screen I use to be able to watch VHS's just fine, but now all I get is a blue screen. The blue screen will also come and go when I try to tape from a VHS to a DVD. What can be done? Thank you.
    Problem Solver:
  • 6 Answers
Could be dirty heads if you have a dry head cleaner tape try it (Maxell and RCA make ok tapes to try for ~:30-1min) ALSO:
There is a delay in the time you adjust the tracking and
the results being visable on the screen on this unit,
I suspect the tracking is adjusted off center. It takes some getting used to the way this deck's tracking adjustment works as the VHS video is upconverted to be captured onto the dvd and that is what you see, the upconverted video, fed out to your TV, analog or digital, this unit upconverts everthing to digital even analog channels, there needs to be a noise/blue screen off feature in the menu like my old hitachi VHS deck and my JVC ~$60 deck has now. On analog TV or old tapes it comes in handy for adjusting the tracking/antenna.
Posted on Mar 12, 2008
I have a Mitsubishi HS-U448 VCR. It plays my VHS tapes fine, but I can't get a blue screen when I turn it on. When I press 'play', the movie looks great. Once I hit 'stop', it'
It sounds like it is set to a TV station and since all the analogue stations have now gone you will only get static. Without a remote you wan't be able to switch it. I suggest you either shop around for a replacement (try Curry's partmaster) or use a universal one.
Jan 16, 2013 | Mitsubishi HS-U448 VCR
Christmas URGENCY: monitor/viewfinder: blue screen, lines of white dashes
remove the tape and just test that whether its recording or not and try to change the tape and then try
Dec 23, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
Vhs tape won't play
sounds like to me the tape is to tight .try rewinding the tape all the way then fast forward all the way till it stops repeat and it should loosen up. if not the tape is no good the blue screen might go away after the tape is loosened n try cleaning the tape player good luck
Sep 19, 2009 | JVC DF420 D-VHS Tape
VHS-C tape jumpy when playing back
My apologies, I overlooked the "-C" in your post.
This problem is due to a type ofcopy protection built into vcr's.
"Macrovision" copy-protection is merely a weakening of a particular part of the signal that makes up the picture and was primarily intended to prevent people from copying videotapes. I imagine almost everyone's seen it but probably didn't know what they were seeing: the resulting picture is a little jittery and is in black-and-white or alternates between black-and-white and color. The reason you're seeing a blue screen is because modern televisions, in the absence of a signal or a weak signal, will just show a blue screen instead of snow or a very poor picture. As mentioned above, you can get around Macrovision by inserting into your connections a signal amplifier that specifically amplifies the portion of the signal that Macrovision diminishes.
Feb 07, 2009 | Maxell HGX-Gold (4 pack) VHS-C Tape
Nothing but a blue screen...ugh!
buy a cleaning cassette and play three times it will work well.
Oct 12, 2008 | JVC COMPACT VHS-C CAMCORDER
VHS Sound - No Picture
try cleaning the vcr with a video tape cleaner
or maby the yellow video output need replacing the cord i mean
Sep 13, 2008 | Panasonic PVQ-M2509 Combo
VCR not working
The heads are dirty or misalligned. Try running a cleaning tape through it. If that fails, it needs to be serviced.
Sep 01, 2008 | Sanyo VWM-800 VHS VCR
Vcr help
This problem is certainly dirty or worn video heads, most likely just dirty. You could try cleaning with a tape head cleaner (wet type) If this doesn't work, contact me again, and I'll email you detailed instructions for cleaning.
Kind Regards....Dave
Jun 10, 2008 | Emerson EWV401 S-VHS VCR
VCS 442 Zenith
one way is to connect an antenna to INPUT of VHS, place a tape, press play, STOP and switch VCR\TV switch to TV. u should be able to change the channels from the VHS. If that don't work, u may have switch problems.
If this works, tell the boss..........FixYa.com
P.S. The 'blue screen' means that you don't have a signal to the antenna inpur\TV protion of VHS.
Mar 27, 2008 | Zenith VCS442 VHS VCR
JVC GR-270U Blue screen with playback
a 1394 cable is specified for the GR - D - 270 but the GR - 270 U , not listed ( does your camera use VHS/c , or mini DV tape ? )
Aug 15, 2007 | JVC GR-AXM710 Camcorder
RCA DRC8335 Logo
122 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
