My timer recording funtion isn't working
I set up the timer funtion but when it goes to turn on. It stops and ejects the tape. I tried a new tape and it still does it. I cleaned the heads and that didn't help.
It does it, also, when i put in a tape. it decides it doesn't like the tape and ejects it and shuts off.
I can however, if the machine likes the tape, hit the record button and it will record.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
You might have an object stuck inside or the belts need to be changed. also the idler could cause this problem. hope this helps.
good luck.
Posted on Feb 10, 2008
MY RCA VCR - TIMER LIGHT ALWAYS FLASHES. WHEN i TRY TO RECORD OR TURN OFF VCR IT EJECTS TAPE.
If it plays a tape OK, then it could be that you have a timer set. In which case clear it! Or that you are using a blank tape where the slot at the back is open. If you are using a blank tape which is good and it still ejects the tape after setting the recording. Then it's likely the recording tab sensor - that detects the slot at the back of the tape - is either bent or broken.
Feb 22, 2013 | RCA Televison & Video
VCR won't record, just ejects tape
You have not mentioned the make and model number of the vcr. Any way the problem is due to end sensor or related circuit. End sensors are photo diods which you can check the shorting with a multy meter.
Jan 13, 2013 | Emerson Televison & Video
Can't get the timer record to set. The tape ejects when I turn TV off. There is some trick and I do not have the manual to figure it out.
Try a new tape, or put a piece of tape over the hole found in the back of the tape you are using. If the record safety tab is still present it may be bent. A piece of tape will rectify this too.
The tab is there to protect the tape from being recorded over by accident. If removed or bent slightly, the vcr will detect it and will not record on the tape.
Most VCRs will eject the tape, or show some kind of error message.
Jan 04, 2011 | Symphonic SL2940 VCR
Tapes won't go down, and then eject.
Have you tried to force eject the cassette. May be the ribon of the tape has come out. Try using another cassette.
Mar 24, 2009 | Panasonic PV-V4522 VHS VCR
VCR ejects tape when I try to record using the timer facility
Simple. The Cassette's 'Prevent Erasure' tab is missing. Just cover with Scotch tape and reload. Now try recording.
Nov 29, 2008 | Televison & Video
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
Cassette
Most VCR's will auto-rewind the tape when it gets to the end of a tape. Most will leave the tape in the unit assuming you may wish to view it again once rewound. Does the tape eject properly when you press the eject button? What does the manula say about the eject function?
- Jim
Jan 23, 2008 | Philips VR550 VHS VCR
Vcr eating and/or ejects tape
Tape heads should be cleaned first and gears lubricated. This job can be done at home if you purchase lithium grease and are very careful not to get it on the heads or spools. Greasing should only be done if you are confident in opening it up. Otherwise, seek a cheap professional.
Oct 26, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tape plays for a while then stops...
play it till it stops when it ejects see if you can spin the wheel with your finger or if it feels like it is hung up try a different tape se if the problem goes away if it does not go away sounds like you need to get the heads cleaned or get a new VCR or better yet get a dvd player/recorder you can get one with a dvd/vcr and record your vhs on to DVDs
Jan 02, 2007 | RCA VR702HF VCR
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
