Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Xerox xd100 what is fault code H4?
    Novelist:
  • 171 Answers
See this thread, someone with a similar problem to you:
http://www.fixyourownprinter.com/forums/laser/24105
I'll summarize the solution:
The "software" H4 problem is quite common that Xerox has a resolution on its website
Solution: Perform a Fault Reset 14
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
1. Find the pink Clear button on the Control Panel of the WorkCentre.
2. Find the button below the word Auto.
3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
5. Press the green [Start] button.
6. Press the pink [Clear] button two times.
7. The WorkCentre should now warm up and come to ready.
8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Feb 08, 2008
  • Frosty555 Feb 08, 2008
    By the way, to answer your question, an H4 fault is supposed to mean that the fuser temperature is too low and so there is a problem with your fuser and it needs replacing.
    However, the code has been known to show sometimes, even when the fuser is just fine. If that's teh case, performing the reset I explained will clear the error.
    If it REALLY IS YOUR FUSER, then the reset won't work. In that case, replace your fuser before you go off and rate this solution.
  • boy nggg yeemlere Sep 05, 2012
    my machine no work helppppppppppppp pleaseeeeeee
Hi my dishwasher is showing h4/5/6, wht does this mean please?
Check this link here
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3714-beko-electronic-dishwasher-fault-codes
H4/5/6 pretty sure it means errors H4, H5, and H6 hope this helps
May 03, 2016 | Dishwashers
Error code H4
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
Toshiba studo120 H4 error code
May 06, 2015 | Toshiba e-Studio 161 Copier Copier
Control panel shows "H4"
This is a solution from the Xerox Support website (www.support.xerox.com) Give it a try and hopefully it resolves your problem. Take care & good luck.
Mar 03, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
I have a Xerox XD 100 work centre showing a H-4 code what is the problem?.
The H4 code on these machines is almost always a false code. Especially if you have had any power fluctuations or failures.
Here is the text from my tip to solving this problem here on Fixya:
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
Sep 03, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Probleme code H4
Press # * C * , that will put the machine into diagnostics.
Enter the number 14 as if you were making 14 copies. Then follow the screen directions to clear the fault code. Should be enter 1 then press start.
The machine will reset and should be fine.
Jul 21, 2010 | Sharp AR-5320 Black and White Copier
I have a number 4 and a letter H flashing
Good Luck and Thank You for using Fixya
Jul 16, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
We have a workcenter pro 45. The new fuser module is on order, but the fuser model went out today. Is there a way to override the error until the new module arrives?
What error? H4? If so then you can get the reset procedure by searching my tip for this under "Sharp AL series H4"
Your Xerox XD100 is made by Sharp
Mar 19, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
I am getting code H4-01. What does this mean?
H4 means you have a HEAT problem, most likely a bad fuser assy.
Jan 25, 2010 | Sharp AR-407 Copier
H4 READING
H4 flashing mean fuser unite fault.Fix it # interrupt C interrupt 14 press start key machine on/ off.If it are not fix change thermostat or Heater lamp.
Dec 14, 2009 | Sharp AR-5320 Black and White Copier
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
371 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
