Question about Toshiba DKT3020SD Corded Phone
Toshiba DK3210SD DADM3220 Set Default Volume Control High for Hearing Imparied Individual
What is the procedure for changing the default volume level to a higher setting, for a hearing impaired individual?
  • johnkyzar May 11, 2010
    I believe you can do this in the pad table in the emanager software. I recently had this problem as was able to purchase a amplified handdset that has been working. Hope this helps.
  • 66 Answers
This must be done through system programming and will require a technician to program this through winadmin, unless you have access to winadmin
Posted on Apr 12, 2010
Hello, I'm trying to increase the volume on some phones mitel 5220 and 5224, but it only goes to 6. I need the volume level to go to 10. Do you have any ideas? Firmware is 07.02.00.04 Thank you
The ADA compliance requires that the phone when set to the highest volume level will revert back to factory default setting for the next call. This is a safety feature to prevent one's hearing aid from being blown up by a loud caller.
If you turn the volume up to 9, and leave it there, it will stay at 9. If you turn it up to 10, it will always revert back to default.
I hope this helps,
Mark
Feb 08, 2011 | Mitel 5220 IP Phone
Cant get the mic to work
Have you set the mic you wish to use with your webcam as Default ?
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Dec 21, 2010 | Gear Head WC330I Webcam
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
When i switch on the sound,a feeble sound (in high frequency) is heard from my laptop
I think you have adjusted the volume label as height level as well as the media player also.Always you would set the volume for media player, and the audio device volume, set as medium.
In another way, I think you have adjusted the equalizer in high performance ,if am I right please set the equalizer as default.
Hope it will help you.
If your problem will be solve ,don't forget to vote me.
Dec 11, 2010 | Toshiba Computers & Internet
My pk-635m camera is working but the microphone is not, what will i do?
If you have XP set your mic as default in the Control Panel
Vista
Plug in the webcam
TEST SPEAKERS
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
Restart computer
Aug 20, 2010 | A4tech PK-635 Webcam
I can't fix my michrophone on msn, even i tried the tools maybe because when i got the windows 7 , i saw many things has been changed on my computer , plz help
If you have a laptop you will 2 mics - try making the webcam mic default
TEST SPEAKERS
Restart computer and configure to msn
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Jul 11, 2010 | Logitech QuickCam Pro 5000 Webcam
My webcam the microphone is not working
Make sure its set as default
Vista If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays Restart computer
Configure webcam to your chat program
Jun 06, 2010 | A4tech PK5
Built in USB mic not hearing me GDMALL 1370 on vista
Recheck default sound card settings in the Record setting. The device needs to show up. Make sure volume is up high enough.
Jul 09, 2009 | ASUS M2N-E SLi Motherboard
Low custom (individual) ring volume
This is not a B/B fault, unfortunatley the person who recorded the ringtone has recorded it at a low level, import into a wave/mp3 studio program and alter the recorded levels.
That is if you have tried the following:
Select Speaker Icon on the front screen of your 8100 (top right) press pearl in, scroll down to advanced, select the current profile (this is defaulted to Normal). Scroll to Phone and press pearl in.
Change Volume to High, if it's already on high, try the option above.
Gadget
May 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
Durabrand CD Home Music System - Volume default
HM3817DTBLK:Default volume
I sent a note to the manufacturer. Communication attached below.
Dear Customer,
We thank you for your interest in GPX and our products. We apologize, but the volume level on the unit is a factory setting that we are not able to override or alter.
Once again, we apologize for any inconvenience this may have caused.
Best Regards,
GPX Consumer Service
>>> "Chris" 12/27/2008 2:02 ">x.x@eds.com> 12/27/2008 2:02 >> PM >>>
The default volume is set way too high on this radio. It is at 17 and we would like to reset it to a much lower level. How do I do this?
Chris
Jan 08, 2008 | Audio Players & Recorders
Toshiba DKT3020SD Corded Phone Logo
430 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Marvin
Marvin
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
