Question about Cuisinart Grind&Brew Coffee Maker and Grinder Combo - BLACK
Set time How do I set the time, andd is the automatic shut off dependent on the time being set.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 62 Answers
1) Press and hold either the hour or minute buttons for three seconds to start the clock flahing.
2) No.
Posted on Jun 30, 2008
Toshiba tv automatic on off
Depends on the model. Some models have energy saving feature
The unique energy saving feature is called 'Automatic Power Down'. This means the television will self-switch into stand-by if no television remote control commands are received within 4 hours. This feature is an energy saving solution for situations where the television may be left unattended for extended periods and has been enabled as the default setting.
You will see an on screen warning prior to the automatic shut down. Automatic shut down will be averted by depressing any key on the television remote control.
Use of automatic power down functions will be progressively introduced to future models in an effort to reduce energy consumption and greenhouse gases.
If you would like to disable this feature you may follow the instructions below (depends on TV Model)
1. Press theMENUkey on the remote control.
2. Press theright arrow keyand highlightSETUP.
3. Press thedown arrow keyand highlightAutomatic Power Down.
4. Press theright arrow keyto change setting toOFF.
5. Press theEXITkey on the remote control.
Some models "auto shutsdown" if it doesn't detect any signal from the TV for around 15mins. Please search for this setting in the user's manual.
I hope it helps!
Jan 23, 2014 | Toshiba Televison & Video
Shut down and show power saver
Open Control Panel, Power Options, Advanced Power settings, Change Sleep to Never, Hibernate to Never. Adjust to your preference.OR right click on a open space on the desktop, depending on the OS you are using, select Properties or Personalize, Select ScreenSaver, set time. It's a good idea to shut down your machine when not in use, even if you have a UPS, Your computer will last longer and a reboot every day resets the computer.
Jan 11, 2013 | Dell OptiPlex Computers & Internet
What would cause the valves to make a clattering noise on a 27 hp air cooled kawasaki engine..
when was the last time you adjusted the valves?pull the valve covers of and feel the arms for movement
Aug 17, 2012 | Garden
I have a brand new Sherman Timeoff Water Timer Model 500 in a box, but there are no instructions. Can you help?
It appears that you turn the dial to any setting from 1 to 13 depending upon how much water you want the timer to dispense. The numbers show relative amounts from 100 total gallons to 400 total gallons, then the timer shuts off.
Gary
Jul 26, 2011 | Garden
WHAT DOES IT MEAN IF THE GREEN LIGHT IS NOT ON? DOES THE SYSTEM REST AFTER THE TIME HAS RUN OUT, MY SYSTEM HAS 88 DISPLAYED
88 means you are filtering alone no chlorine
Once the generator is set it will run its time like 1-12 hours depending on what you set it at
After this time it will flash 93 meaning it is getting ready for sleep mode eventually it will shut that down and then turn back on at the same time you programed it the time before
There are 2 green lights
top one is that you are filtering
second one comes on about 2-10 minutes after you set the generator time this shows you are producing salt
Jun 14, 2010 | Intex Automatic Salt Water System for ...
Automatic shut off?
Usually you set this by going into the power saving settings in the screen saver settings.
You can set the monitor to shut down pretty much when you want it to from this settings screen.
Good Luck,
-a.
Jun 07, 2010 | HP 2009M Monitor
Car restarts after automatic shut off
When you use your remote start system the vehicle will run aprox. 15min. ( depends on your settings,check your manual) But will go thru a cycle and shut it self off and then restart the vehicle again until you either push the remote stop button,depress the brake,open the hood or insert the key.
Dec 27, 2009 | Python Vehicle Parts & Accessories
Date andd time is wrong
Open one-touch speed dial panels. Press 'Data Registration' button. Press 'Set'. Arrow down until Date/time is displayed. Press 'Set'. Make required changes. Press 'Set'. Press 'Stop' to return to standby mode.
Nov 05, 2009 | Canon LaserClass 9000L Plain Paper Fax
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
flash. This signals that you have entered the
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind&Brew Coffee Maker and Grinder Combo - BLACK Logo
29 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
