Question about KitchenAid KSRP22FNSS Side by Side Refrigerator
Ice dispenser stuck on crush
Model of the fridge is frigidare it is stuck on crush, even if you empty and clear out all the ice same thing, any ideas?
  • 83 Answers
You have a bad computer board behind the ice despenser.
Posted on Feb 09, 2008
Power to the ice maker/water dispenser seemed to have shut off. Ice maker is still making ice, but the dispenser is not working. Is there a fuse or something?
frigidare 36' side by side. makes ice, nothing comes out of the door dispenser, auger truns. prior to this it would only give crushed ice even if set on cubes
Dec 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Frigidaire Model GLHS68EGSB2, ice maker will only dispense crush ice even if you press the ice cube dispenser
You need to take out the ice bucket, empty it, let the bucket sit in the sink for a few hours. Ice builds up in the crushing blades and jams them, let all the ice melt out of it and it will be fine
Oct 27, 2009 | Frigidaire Refrigerators
Will only dispense crush ice
sounds like you have a stuck dispenser solenoid.
look in the back of the freezer where the bucket shift arm enters the drive assembly. i would guess the actuator is stuck in the "up" position. the solenoid usually sticks up and should be cleared and lubricated so frost does not cause the solenoid to stick up.
Sep 15, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker only will give crushed ice. Pressing cubes changes the light but still get crushed ice.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 19, 2009 | Frigidare FED300E Electric Range
Ice dispenser only dispensed crushed ice, not cubes.
there is a metal rod that sticks out the back of the ice maker bin, it has a spring around it. it needs to fit into hole in the back of the fridge.
May 17, 2009 | Frigidaire PLHS269ZD Stainless Steel Side...
Only get crushed ice, even when Cube is selected
Hi
1 thing to try first is pull ice bucket out and make sure the bar at back goes through the vavle in rear panel. cause if it isnt then when you select cude the vavle isit lift up.
regards
Mar 22, 2009 | Electrolux Refrigerators
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
ICE Maker stuck in dispensing crushed Ice
That means that the evaporator fan system that releases the the ice cubes is not working.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Nov 29, 2008 | Frigidaire GLRS267ZC Side by Side...
KitchenAid KSRP22FNSS Side by Side Refrigerator Logo
105 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
