Problem for Copiers
Generic problem for all Copiers
Konica 7255 diaplays a F56-04 code when IP ...
Installing (adding) IP to Konica 7255 copier. When IP is installed and copier turned on, copier warms up, display works, when test sheet should print, code F56-04 is displayed (not found in service manuals).
Comments:
Feb 08, 2008
- Yes, it is.
We are speculating that the IP511A may be REQUIRED for the 7255. But we are still open to other theories.Feb 08, 2008
- Will get back to you next week.
We are getting a 511A (I am a copier dealer if you had not already surmised that!!)
Thanks for your help.
Were you able to locate any documentation that even mentions the F56 codes - we couldn't.Feb 08, 2008
- We'll know next week.
Thanks for your help - will check back when I have a confirmed answer.
Clarification Request
Posted by Nitrotrike on Feb 08, 2008
I am assuming this is the IP511 print controller?
Best Solution
posted on Feb 08, 2008
Rank: Guru
Rating: 88%, 843 votes
That is correct. The IP511A is for the 7255 / 7272, and the IP511 is for the 7155 / 7165.
This is probably due to these machines using different image processing boards.
I am actually surprised it lets you get as far as you did with it.
Comments:
Feb 08, 2008
- I looked through my stuff too, and couldn't find it. But if memory serves me right, F56 / E56 codes usually point to a image processing communication error in one way or another.
In typical Konica fashion, It may be in the IP511A service manual itself (which I couldn't locate either).
Popular Solutions for Copiers
Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier
1 Solution
Questions and Unsolved Problems for Copiers
What do customers think of the the Toshiba e-studio 5520c, as we are considering buying one?
Hey!
I've been using my Ricoh Aficio 2015 as a copier over 5 years now. I would like to convert it...
(More)
Hey!
I've been using my Ricoh Aficio 2015 as a copier over 5 years now. I would like to convert it to a scanner/printer too. I was told that there are 2 options available, 1 is the normal scanner/printer kit and the other the all in one scanner/printer/fax kit. However, to me it only seems logical to setup a scanner/printer kit considering the age of this machine and also the cost difference between the 2 kits.
But now it seems that the scanner/printer kit cannot be installed to this machine, but only the all in one kit could be installed. Why is that?
Regards
CompleteCopierNoob
I have a casio boss business organizer scheduler system sf5300 and I haven't used it in about 3...
(More)
I have a casio boss business organizer scheduler system sf5300 and I haven't used it in about 3 years. I bought new batteries and installed them ne at a time but the boss won't turn on. There's nothing on the screen. What can I do.
our panasonic dp-8016p is configured as a network printer. suddenly some of the user cannot print.
Where do I buy audio cotton swabs recommended in your PC428 Operator's Manual to clean the fiber...
(More)
Where do I buy audio cotton swabs recommended in your PC428 Operator's Manual to clean the fiber lens
