Question about Lexmark Wheelwriter 3 Typewriter
IBM Easystrike Cartridges
I am having an issue with the IBM Easystrike black #1380999 cartridge breaking after a few typed words. The issue is is that the black (ink) band keeps breaking after a few typed words!!! So then I put a piece of tape on the advance ribbon and the black(ink) band and now it works. My issue is is that I broke two of them before I got it to work correctly. Any way to fix the broken ones???
Any info would be great.
~Kaity - kaity.bench@gmail.com
  • Lexmark Master
  • 3,594 Answers
The ribbon cartridges can be pried apart they are pressed together, getting it apart is easier than putting back together.
Next time you have to install a ribbon advance it by hand for a foot or so as old ribbons tend to stick to themselves.
Hope this helps
DickyO
Posted on Feb 11, 2008
Trying to print documents, white background with black typed words. Problem I have is the printed documents have solid dark blue and solid black ink and the words don't show.
Are the ink cartridges installed in the correct colour order?
Have you printed a test page through the printer's own control panel? What was the result?
Open a new document, using the default settings. Key in some test text. Try printing. What is printed?
Jan 06, 2015 | HP Office Equipment & Supplies
Hp 8500A won't print if one ink cartridge needs to be replaced
Its simply because the cartridge is not making a good contact with its socket.
1-switch off the printer and totally unplug it 2-clean the cartridge properly
3- check the cartridge clip
4-return cartridge and send a feedback to us
Jul 09, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
After changing the ink cartridge it gives me the message, the type of print head is incorrect...Canon MP830....I installed it over and over again, same result with several other cartridges
Hello.
This can happen with certain types of compatible cartridges. the large black is usually the issue. Try unplugging the printer from the power for 5 mins. Also Try replacing the large black with a different brand, compatible cartridges are great for saving money but can cause some issues with the electronics. I recommend G & G Brand compatibles. they have been rated very well in PC Magazines and give no issues with recognition.
Regards GM
Jul 01, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I could only get 1/2 of every letter. It is a IBM select wheelwriter. How to fix? It uses a IBM ribbon #1380999
You probably have an IBM Wheelwriter. Press down firmly on both ends of the platen (black roll) it should snap into place.
DickyO
May 24, 2011 | IBM Office Equipment & Supplies
Black print is faded on my HP deskjet 6980 printer. Whenever I print a word document it will have sporadic fading. It will be fine in one place then all faded in another. I've cleaned the cartridges and...
Here are some steps you can check to resolve your issue.
Check if the ink cartridges are low, specially the color black since if the black is empty, you are using the colored cartridges to print black. If the cartridges are newly replaced check the cartridges by reseating it. Try to consider changing the print quality high but doing so will use more ink. If still the same try to clean your printer heads.
Here are the instruction for cleaning your printer.
Open the printer tool box. (open a word, then click on file then print, choose properties, then services)
click on clean the print cartridges, then clean. Do test printing as well to check if the color is correct. If still the same calibrate the color which can be found in the same menu.
For more information here is the link for step by step instruction with visuals.
Hope this will help you resolve the problem.
Thank you for choosing fixya
Mar 03, 2011 | HP Deskjet 6980 InkJet Photo Printer
Wheelwriter 35 cutting off bottom of letters
First thin to do is to be sure the platen (rubber roll) is fully seated in the T/W side frames. press firmly on both ends of the platen.
DickyO
Mar 02, 2010 | Lexmark Wheelwriter 35 Series II...
My ribbon broke, I don' t know how to fix it.
The ribbon has 2 little (feet) on the rear of the cartridge they hook into the ribbon deck and it just rocks into place. You can get a picture and instructions @ lexmark .com klick your way to publications. Be sure to advance the ribbon by hand a foot or so to be sure it isn't sticking to itself.
DickyO
Sep 29, 2009 | Lexmark Wheelwriter 3 Typewriter
Faint printing on checks
To my knowledge the 999 ribbon is the best avaivable. Try these things. put a little light (WD40 works well) oil on the back side of the print solenoid, then perss code and "Q" the display will show 1,2 or 3 set it at 3 and then try code "B" for bold print. These should help.
DickyO
Feb 02, 2009 | Lexmark Wheelwriter 3500 Typewriter
Replaced Part No. 1337765 and 1380999, but there is still no ink coming out
It sounds like th4e plastic cap on the print solenoid plunger is broken. The part is avail. but a little tricky to replace.
DickyO
May 16, 2008 | Office Equipment & Supplies
Lexmark Wheelwriter 3 Typewriter Logo
76 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
