Sony Ericsson W200i Cellular Phone Logo
Posted on Feb 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motorola v710 cell phone
I have a 3 month old motorola v710 phone that won't hold a batttery charge.
I have lowered many settigs and use the battery saver option. I just purchased a new battery, charged it for 24 hours, let it set overnight with the power turned off and the battery was low the next morning. The phone works fine it just runs down the battery after a full charge within 10 to 12 hours even when it is off. My email is [email protected].
  • yarrlsouth Feb 08, 2008
    Yes it is lithium ion and I will keep charging and draining and see if it helps the battery.
  • Anonymous Jan 09, 2009
    i think these v170 lithium batteries were probably made in the stone age and that is why they are just no good anymore. i am going to get another phone. (
    I bought new batteries AND a new phone and still had the exact same problem)
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
589
Points
Yarrlsouth,
I use http://www.sears.com/shc/s/dap_10153_12607_DAP_Battery+Finder
when I need to find a battery. It may help in the future.
Anonymous
Level 2:
  • Expert 80 Answers
  • Posted on Feb 08, 2008
Anonymous
Expert
Level 2:
Answers
80
Questions
0
Helped
36055
Points
116
Is the battery lithium -ion? If not, you have an older generation of battery.
Having mentioned that, some batteries need an introductory "conditioning period". Continue your excercise of charging and draining (dont drain too too low) and hopefully you will start seeing some decent longer lasting charges.
Hope that helps!
2answers
How do you turn on a motorola v710 after is has charged
push green button and hold on for a couple of seconds.
How many hours did the batttery works can u please tell us
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged state for long periods.
The battery doesn't work fine
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
3answers
Why its battery quickly drains
1helpful
My battery died on the Nokia 6790 Ive been charging the phone for over 3 hours and only the keyboard lights up when i hold the "on" button but the screen doesnt turn on
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
I have a Motorola V710, it will not power on but the screen blinks when plugged in to charge, what's wrong?
The batery may not be holding a charge anymore, try removing the battery and clean the contact's, if that do'es not work the battery may need to be replaced.
2helpful
V710 Motorola will not power on but screen blinds off & on plg in
I think there is some problem @ your battery. Change the battery & check whether the screen works or not if it ask for unlock code you can get the code from motorola code
2answers
Removable memory
Have you tried reformatting your memory card? I had a similar problem with my rezr and that's how i fixed it. -Lacy
4answers
Doesn't turn on!!
you need to try and get into the boot loader to see if you can flex/flash it from there. a new flex should solve the problem, unless there is physical or water damage to it. It could also be a defective battery. Are you positive the battery works? Did you do any kind of upgrade on the phone? played with it's firmware? On flashing - http://wiki.howardforums.com/motorola/index.php/How_to_flash_with_RSD_lite Flexing is done the same way Good luck
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
