Question about Frigidaire FGF378AC Gas Kitchen Range
Frigidaire FGS365ECD gas range, oven won't heat up
I have narrowed the problem down. Doing some research i learned that the gas to the oven starts when the electonic starter heats up to a certain temp which allows the gas to burn. The problem with my oven is that the electronic starter is not heating up. How do i check and see if it is the wiring or the starter itself? What would cause this problem and how much would it be for a new electronic starter which i think i will have to buy?
Thanks in advance
OIF Vet
  • truthphil2 Jan 15, 2009
    how do I replace it.?
    truthphil2@hotmail.com
    Thank you in advance
    Habit-Forming:
  • 171 Answers
Yes, it is the ignitor the glow part nest to the oven burner needs to be replace, if you see that it comes on but the oven gas does not, it tells you that everything in the sisteme is good. or even if you donot see it wlighting change it any way,thats the problem. price is not more then $40.00 dollars.
Posted on Dec 08, 2008
Oven won t heat up properly
Hello Greg, I am happy to assist you. Let's try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait roughly ten minutes and then turn the unit back on. If you have a gas range, while the unit is turn off; confirm that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. Then you may turn the appliance on. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. The unit could possibly be experiencing a potential wiring failure, faulty EOC (electronic oven control), sensor probe and/or bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Aug 05, 2013 | Frigidaire Kitchen Ranges
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
Oven won't heat up when baking (Maytag MGR5775QDS)
Check the Manual/Auto Clock setting to be on Manual not auto . The Oven is waiting for the Right Time to start up .
Jun 13, 2012 | Maytag MGR5775QDS Dual Fuel (Electric and...
My oven will not heat-neither the bake or the broil. However, the stove top works fine. Could you tell me what might be the problem?
your oven ignitor has gone bad, its located at the bottom of the oven and tells the gas too turn on and light the oven, fairly simple to replace, once on has researched it online.[ youtube videos] i just replaced ours last fall a week before thanksgiving. i hope this helps
Aug 13, 2011 | Frigidaire FEF339E Electric Range
Oven won't start
Very interesting. The ignitor is working, so that means you have power and the control is working. The safety valve is working, and you have a complete circuit. So why won' t she fire off? Inside the safety valve is a bi-metal that only opens if the resistance is right. The resistance only changes when the ignitor is on. As it gets hotter it changes in resistance. This allows the gas safety valve to release the gas and ignite. Watch this:
May 07, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Frigidaire gas stove/range heating problem
it might just need a good cleaning sometime dust and soot builds up and needs cleaned out of the burners but you can check the thermomitter with a multimeter ohms test if current flows through it
Oct 26, 2009 | Kitchen Ranges
Frigidaire range
narrow it down to either the broil coil (upper) or the bake coil (lower). then find the control knob which sets each function and then replace that complete knob assembly.
May 30, 2007 | Frigidaire FEF355 Electric Kitchen Range
Frigidaire FGF378AC Gas Kitchen Range Logo
814 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
