Panasonic TV pincushion adjustment
Hi: I have a Panasonic CT-20SX12DF TV thats in great condition but image is squezzed inward in the middle. How can I adust this. Can it be adjusted like in my computer monitor?
Thanks for your help
Carlos
  • Nell Hamilton-Schulz May 17, 2009
    concave picture on otherwise perfectly good 68cm Panasonic TX_66PW150A teevision.
    Is it worth repair cost?
  • 30 Answers
Try to adjust yuor fucos and screen at hte flyback.hope this will help
Posted on Feb 09, 2008
The picture on the tv is curved in the middle sides if the screen how do i fix it to where the picture fills the whole screen?
Their are pincushion circuits the compensate for inward curvature. It is common for solder connections to break on the pincushion transformers or the connections where the transformer wire is wrapped around the connector pin. Careful inspection under a magnifying glass while manipulating the pin sometime will show hairline cracks in the solder. Their are also adjustments on the convergence board that will compensate. The adjustment potentiometers on the convergence board also have shown to be prone to solder cracking on the PC board
Oct 13, 2009 | Televison & Video
NEED TO ADJUST THE VERTICAL SIZE OF A PANASONIC TV
Has the image been "zoomed" into?  This is usually the result of a image that has been adjusted to fill the screen.  This is not the same as adjusting the aspect ratio as that would still show the entire image even if distorted.  When the image is cropped or is missing information, a zoom feature is usually the culprit.
If this isn't the problem, you maybe able to adjust the TV's horizontal/vertical placement through the TV's onscreen menu but only if it provides that option.  Do you see other channels that appear to fit properly?  I have seen certain channels not fit correctly while others do and this is due to the signal, not your TV.
Mar 25, 2009 | Panasonic Televison & Video
I have a Toshiba CX32D60 with sides of screen bowed inwards ( narrow in the middle). Sound bar raises and lowers - sound audible only, close to the plus (+). Any help will be appreciated. Thank You.
You need to adjust the Horizontal Pincushion adjustment of your TV. That will fix the "bowing" which is actually Pinning.
Check the audio source to your set.
Mar 06, 2009 | Toshiba Televison & Video
PANASONIC 32" CT-27SL14 model
This is a problem with the pincushion and convergence circuits. Are you planning on repairing this yourself? If so, I'll look up the circuit designations and parts. If not, expect a parts cost in the $15 range plus the local labor rate.
Dan
Jul 03, 2008 | Panasonic CT-27D31 27" TV
My Panasonic CT-36SX31 picture has an hour shape
Take a look around (say, within 12 feet of) the TV... anything that can generate an electrical field? Microwave... refridgerator... old school stereo speakers...
Pin cushioned is a term applied to a picture that's doing what you described. Adjustments to correct that are typically found in computer monitors.
I have an identical television to yours and that adjustment isn't available. You could try degausing, but I doubt that works.
Jan 27, 2008 | Panasonic CT-36SX31 36" TV
Apex PF3230 TV with pincushion problem.
too dangerous for a home repair as this requires replacement high voltage components and adjusting the set with the back off while running.
Take to repair store.
Nov 08, 2007 | Apex Digital PF3230 32" TV
Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Dec 05, 2006 | Panasonic CT-27HL14 27" TV
Pincushion??
There is a pincussion correction circuit in this RCA TV set that does have problems from time to time. Its in the horizontal High voltage sweep circuit and should only be worked on by a trained tech as there is alot of High ZVoltage there. In this set there is no user replaceable parts inside, as everything is soldered into place. It could be in your case a pincussion correction driver transistor or the coupling capacitor or capacitors that need to be replaced. if your not trained in the high voltage circuits , for your safety, please call in a local repair person to assist you in this repair.
Sep 23, 2006 | RCA F32650 32" TV
Televison & Video Logo
488 people viewed this question
Top Televison & Video Experts
Electro Med Services...
