ASUS P4S8X Motherboard Logo
Posted on Jan 12, 2010
What is the best way to resolve the freezing issues using a P4S8X-X motherboard?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Apr 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
1713
Points
9
There are many possible causes and solutions for your mobo problem. try these options one by one:
1. check your installed system memory. if you have two(2) modules, try removing one and leave the other one on and turn the power back "on". and vice versa. check which one works without freezing your system. remove power plugs before doing this.
2. if you only have one(1) memory module, try removing it after shutdown and unplugging the power cord and transfer the module to another slot. then power your system "on". if this doesn't work, try to slightly sandpaper the terminals of your memory module(s), just the terminals. then clean it with a new/clean small paintbrush and install it back on. power on your computer.
3. check the memory clocks of your installed memory modules. it should be of the same frequency. memory capacity (mb); it doesn't matter if one is higher than the other as long as the clocks are the same.
4. if all these options that i mentioned/stated above doesn't work. try replacing your memory module.
2helpful
2answers
Pleas i want audio driver P4S8X-X
you have not specified the windows version you are using.
If you go to this site and select the motherboard number and windows OS, it will give you the drivers you want.
Hope this helps.
P4s8x-x parts and name list
To know all about your ASUS P4S8X-X Motherboard, please refer to the product user manual, which can be downloaded from the following site
http://porthos.ist.utl.pt/ftp/windows/Drivers/asus/e1217_p4s8x-x.pdf
Hope this answers you questions
CreativeTECH
2helpful
Configering vga grphic card sis real 256e on board asus p4s8x-mx
Install the driver whicj came along with the motherboard will resolve your problem.
Thank you for using Fixya.
DOES THIS MOTHERBOARD SUPPORRT 64 BIT
In order to run Windows XP x64 bit you're CPU must be x64 bit
compatible. Included below is a link to all supported CPU's the mother board P4S8X-X can handle;
(None are compatible with x64 bit).
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P4S8X-X&product=1
Here is a little information for you.
Exploring Windows XP Professional x64 Edition;
http://www.microsoft.com/windowsxp/using/64bit/russel_exploringx64.mspx
Cheers'
Mike
How to conect case audio wire to the motherbord so i can lister and talk with my earphone?
The motherboard manual is available here
http://support.asus.com/download/download.aspx?model=P4S8X-MX&SLanguage=en-us
Look at page 40 and it shows the position and pin connectors.
If your case has a solid block connector then you can't go wrong.
Best of luck
1helpful
A bios nao reconhecer o son
Verificá-lo durante a inicialização do BIOS http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=270&SLanguage=en-us
BIOS mais recente Baixe para P4S8X-X de
http://www.roxysoft.com/drivers/ASUS-P4S8X-MX-Bios-v-0502-download-driver/
Siga as instruções e instalar:
http://www.asus.com/999/html/events/mb/ezflash.htm
During bootup check you bios http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=270&SLanguage=en-us
Download latest bios for P4S8x-X from
Follow instructions and install:
3helpful
2answers
Cant find sound driver for asus p4s8x-x
You can download the driver from the following link
Download ASUS P4S8X X Audio driver
I hope this will solve your issue.
Goodluck
If my solution proves useful please accept it.
Regards
Arjun
2answers
ASUS P4S8X-X
Yes, this is a RAM incompatibility since the motherboard don't support PC3200, you can check this link for the complete specs of this motherboard http://reviews.cnet.com/motherboards/asus-p4s8x-x-mainboard/1807-3049_7-30158119.html
Hope that helps.....
Don't forget to rate the solution FIXYA thank you....
7helpful
2answers
Asus p4s8x-mx support CD
If you want a copy of the CDs contact Asus by clicking here and ask if they can sell you a replacement cd for your model.
Instead of getting a replacement CD you can download and run the drivers from Asus download page here:
DRIVERS for Asus P4S8X-MX Motherboard
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
