Question about Soltek QBiC Mania EQ3501 Barebone
Noise bought a qbic mania, when the system has been on a while the fan inside gets really noisey, really it sounds like it has got a turbine engine starpped to it. i have turned the fans down in the bios but when i do this the system gets too hot, windows starts playing up and sometimes it shuts down the pc
  • 37 Answers
Maybe the fan needs cleaning, probably clogged up with dust.
Posted on Feb 19, 2008
When I press the accelerator there is a noise inside the car as though the fans have been turned on
If your battery is weak, the accelerator will boost the cars 12v power enough to speed up your fans if they are on...otherwise, maybe you have a driver - passenger area firewall hole...will really sound loud when you rev the engine.
Oct 19, 2014 | 2009 Ford Focus
Only able to use part of computer
you need to install the hardware driver for each part. you will need the cd driver pack that also comes with your PC.
Jul 27, 2008 | Soltek QBiC Mania EQ3501 Barebone
Rinnai r85 exterior propane tankless water heater makes knocking/clicking noise. seems it tries to start with clicking noise then no fire in burners then cycles again. no error message. have two rinnia...
on start up the clicking noise is normal as well as knocking noise ....one important item with fan , if the fan was removed cleaned and then reinstalled with power to unit could have ruined the fan and it will have to be replaced..... Cant tell you why is wasn't firing before with no codes...other than flow sensor not working( most likey stopped with sand fragments or trash) the flow sensor detects hot water demand and ignites heater and if clogged it will not light up but doesn't give error code and the water running through hot side will be cold..... flow sensor is a turbine that detects water movement and lets heater light..... may want to get serviceman to check this out and clean turbine.... hope this helps...
Mar 27, 2014 | Heating & Cooling
Chrysler town country noise
Your cars engine "roars" or the fan motor "roars"? If its the engine, does your car have tachometer and what are the rpms?
Oct 16, 2013 | Cars & Trucks
I have a GMC 2003 Envoy, each time i drive it sounds like im speeding but im going really slow , i need to change the oil could this affect that and what do i do about the sound
Difficult to know what sounds like speeding: engine, road noise, what ?
If the oil change were to help, you have bad, bad engine problems. I suspect you may have a wheel bearing that may have failed. This makes a lot of road noise, alters with vehicle speed and NOT engine speed (drop to idle, noise the same).
There is a possibility of transmission slipping. this lets your engine speed up, but not actually move the car.
There is a third common issue and that is FAN. When your fan clutch fails, is locks up a normally free spinning (somewhat) fan, as if the vehicle needed max cooling... This noise follows engine speed, the vehicle seems to go just fine, but huge noise.... This sometimes is called Jeep fan noise, as many of those used to have direct drive fans.... If this is your case, the fan clutch gets replaced, not huge $, but more than it should be.
Nov 27, 2010 | 2003 GMC Envoy
We bought Toy Story Mania used with no instruction manual. Where can I find an instruction manual online?
I'm not really sure where you could find it, but if your willing to do this .... you should talk to a manager of the store where you guys got the game.... good luck! :D
Oct 17, 2010 | Nintendo Toy Story Mania for Wii
Hi!i got honda accord i-ctdi 56 reg.there is very loud whistling turbo noise when the engine is cold ,it gets bit quieter when engine warm up. i just bought this car and dont know whether this is normal...
"I have the same problem. Some people say hat the turbine is done. But the problem is that the turbine works normal, no excess smoking, no power loss. So that is why I went dipper into the problem. It turns out it could be the intake header gasket.
I will take it to a local mechanic and let him take a look at it.
Aug 31, 2010 | Honda Accord Cars & Trucks
My computer is becoming really hot and noisy. After turning on the computer, everything is good (no noise). Once around 15 minutes passes by or I open up a lot of programs together, my computer starts...
Sounds like the fan is wearing out, as it heats up the fan needs to spin faster and if the bearings are wearing out it will start getting louder and it will also get hotter because the fan cannot keep up the heat being produced. You can replace the fan, most computer shops will carry replacements, also get a can of compressed air and give the inside of the computer a good cleaning. This will help keep things cooler as well. Also make sure that the air vents on the outside of the case are clear as well.
Jan 07, 2010 | Vantec Fan Vibration Dampener Noise...
Loud whining noise
had 2004 tb has a chip on the cooling fan its self your fan may be going out does sond like a turbin or a jet lol if so its the fan sensor
Sep 29, 2009 | 2006 Chevrolet Trailblazer
Fan makes a lound noise and power button is orange
It sounds as if your power supply is cooked because the cooling fan has been running slow
Only way you can check is to take a panel off and hook a voltmeter into the 12v & 5V supplies on the Hard Drive and the Floppy Drive.
Jun 25, 2009 | Dell OptiPlex GX280 PC Desktop
Soltek QBiC Mania EQ3501 Barebone Logo
Top Soltek Computers & Internet Experts
John Anderson
John Anderson
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
