Question about Microsoft Windows 98 for PC
Win 98 has a key on screen
The key on the screen has a 2-5 digit code that I can not crack! It will not start up normally & it is not hooked up to the internet.
Thanks,
Christine Allen
810-987-6399
yocma@yahoo.com
  • 1 more comment
  • yocma Feb 08, 2008
    It turns on now but no sound card. Any ideas how to restore the sound??
    yocma@yahoo.com
  • yocma Feb 11, 2008
    The sound card must be in the CPU. I have an IBM Aptiva E series 245 AMD K6-2 Processor 64MB / expands to 256 MB
    I hope this helps you help me. It runs now but no sound.
  • yocma Feb 20, 2008
    It just decided it was gonna work today after 2 weeks with no sound & showing as no sound card installed. Thanks for all your help. I did check your suggestion & all plus signs were active, not any exclaimation marks. Thanks again!
  • 145 Answers
What type of soundcard do you have? Is it onboard, if so what motherboard is it?
Posted on Feb 08, 2008
  • Patrick  Haines
    Patrick Haines Feb 11, 2008
    Ok if you boot windows and go in to your control panel, click on system settings then device manager. Are there any hardware errors? They will be marked with a exclamation mark, if so try selecting the device and choose to update the driver. If this doesn't work or there are no conflicts let us know and I will try again.
  • Patrick  Haines
    Patrick Haines Feb 20, 2008
    No problem, just glad to hear things worked out for you.
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
Tip
What to do if you want to start a corrupted win 98?
If ur Win 98 system has been corrupted,means only the windows 98 screen appears and then a blue screen appears or after that the system dosnt start or restart follow the following steps:
1. at the time of POST (i.e when u hear the beep sound or when ur monitor shows the first displays) press the F8 key continuously . then select the option Start in Command prompt only
2. in command prompt type C:\>cd windows\sysbckup ( assuming c: is ur system or root directory)
3. then type c:\windows\sysbckup>dir *.cab
4. now select the file depending on the date closest to the date when ur system was operating fine( the file name will be like RB001.cab )
5. now after selecting the file type in the command prompt c:\>windows\sysbckup>copy rb001.cab ..(assuming the file name as rb001.cab)
6. then type c:\windows\sysbckup> cd\
7. then type c:\> extract rb001.cab/e
8.now restart ur pc
happy computing
on Jun 01, 2010 | Computers & Internet
My 98 a6 audi has the radio locked what is the code and how can I unlock it.
IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
The sequence of programming for 2000 Audi A4 radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Jan 18, 2011 | 1999 Audi A6
Entering radio code for 98 Audi A4
IMPORTANT NOTE: You must have the security anti-theft code for yours Audi Concert radio from the car manufacturer! For Audi Concert the sequence of programming is:
Oct 17, 2010 | 1998 Audi A4
Got win 98 disc restored pc but no key code for it
Giving away key codes is illegal, you won't find one here.
Oct 24, 2009 | Computers & Internet
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 23, 2009 | Konica Minolta Office Equipment & Supplies
98 Dodge Stratus won't start
Best place to start is with "check engine light". Put vehicle in park, foot on brake, and cycle key on, off, on, off, on, then wait with pen & paper ready to read flashes of check engine lamp. Will be a 2 digit code each time. For example, flash, short pause & flash, will be 11, or flash, flash, short pause, flash, flash would be 22. In between trouble codes you'll get a little longer pause, then it will start to flash again if more than one code, which is quite possible. Also note that I say key to on, not start, just on.(normal run position) Then get back to us and we'll be able to better help you.
Nov 28, 2008 | 1998 Dodge Stratus
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
Serial code to install windows 98
Windows 98 Serial Code will be present at the Back of the CD package cover along with the Universal Bar code. i have 2 pirated serial key for windows 98. have a try with this keys hq6k2 qpc42 3hwdm bf4kj w4xwj and
tmv73 8vyg6 tyctr trd6k yv9pw
Nov 11, 2007 | Microsoft Windows 98 for PC
Microsoft Windows 98 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
